Old 08-02-2004, 02:43 PM   #1
Question So where is it?
CAn anybody out there tell us where the drain is for the fresh water holding tank on our 1976 Tradewind 25'?
Zenguin is offline   Reply With Quote
Old 08-02-2004, 02:46 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Carnac says:
What are some red round valve handles under the kitchen sink, slightly below the floor?
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-02-2004, 02:57 PM   #3
LOST , Hawaii
Originally Posted by thenewkid64
Carnac says:
You keep digging oldies up like that and you aren't going to be able to use thenewkid.
John
74Argosy24MH is offline   Reply With Quote
Old 08-02-2004, 04:10 PM   #4
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
3543 posts = not so new
but has great answers
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 08-02-2004, 05:31 PM   #5
JohnG's Avatar
I just checked the service manual and it dosen't show it's location. However, common sense would dictate that it is on the bottom of the trailer somewhere. It should be near the tank or attached directly to the tank.
Sorry I couldn't give a precise answer................
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-02-2004, 07:55 PM   #6
blucloud's Avatar
2007 27' International CCD FB
1987 25' Sovereign
1977 23' Safari
North Olmsted , Ohio
Images: 20
Fresh water drain
For what it's worth....we have a 77 Safari and have been looking for some time for a fresh water drain. The Owner's manual as well as the Service manual both state " turn the water pump to the On position to expel water from the storage tank." From others I've talked to say that it probably was a cost savings by not installing a drain.
If the 76 fresh water tank is similar to the 77 there will be an access cover under the TT forward of the axle. Removing the cover will expose the pick-up line to the pump as well as the tank sensors. It would be possible to splice in a drain in the pick-up line. NOTE!! , the pick-up is not on the very bottom of the tank...there will remain about a 1/2"-3/4" of water at the bottom.
Dave
You never know what you can do
until you try to undo what you did.
blucloud is offline   Reply With Quote
Old 08-02-2004, 08:54 PM   #7
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Had the same trailer
The drain valve is under the trailer midline just back of the entry door.. we are trying to remember this as we have sold this A/S.There is a square plate with bolt in the center. Remove this bolt and viola there is the drain valve.. Enjoy your trailer.... Annie and Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
