Old 08-09-2014, 07:13 PM   #1
merrypaws's Avatar
1976 25' Tradewind
xxxx , Delaware
Smelly water issue
In March I de-winterized my 76 tradewind for MY first time. Prior to that it was sitting in the POs driveway for at least 2.5 years with the pink af in the lines. I flushed everything and then bleached everything and it seemed fine. Because of personal issues I have not used the water lines since then until today. At first I noticed a rotten egg smell in the trailer. I figured it was the water from not being used. So I hooked up city water to flush the lines. The hose water before the inlet does not smell, but once it comes out my faucets, ew! It sort of smells like the pink af mixed with rotten eggs and latex paint. It's an odd smell for sure. I flushed it for a LONG time but it never got any better. Any idea what's going on?
merrypaws is offline   Reply With Quote
Old 08-09-2014, 07:33 PM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Did you drain the water heater? If not, do that & start over with the running of clear water.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-09-2014, 07:58 PM   #3
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Chances are if the water heater was full and it has an anode rod, the tank needs to be drained, and rinsed well and a new anode installed. That is about the only thing I can think of that would cause this smell.
Good luck!
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 08-09-2014, 08:23 PM   #4
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Smelly water issue
There are also anaerobic algae that can take up residence in water systems left idle and as they multiply and feast, they give off sulphur gas which may be your odor. The algae is harmless - per many sites, the water ceases to be palatable long before the buildup concentrations can become harmful.
It happened to me earlier In the season. Flushing the tank once cleared it for my concerns when camping and now I just keep the fresh tank drained when in storage. If it's of major concern to you, consider a system sanitizer ion procedure.
Ian
2011 Airstream International Serenity 28' - 30a/taupe
2013 Fors F150 v6-ecoboost with max tow and HD payload packages
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Smelly Fresh Water Madhungarian Fresh Water Systems 14 07-20-2014 08:13 AM
Smelly water PhiDor Fresh Water Systems 15 09-08-2013 04:45 PM
Smelly/foamy water HermitCrab Fresh Water Systems 9 09-03-2012 09:47 AM
Smelly hot water Bella Casa Fresh Water Systems 7 08-04-2010 06:31 PM
Planning how to refloor a 66 Sovereign: currently, smelly carpet & pad over linoleum Becky Repairing/Replacing Floor &/or Frame 13 09-05-2005 03:34 PM
