Old 11-16-2012, 08:24 AM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Small round bulb w/ schrader valve ???
On our, new to us, '01 30' Excella I see next to the water pump a round bulb approx. 4" d with a schrader valve on the top. From my limited knowledge of plumbing I might think this is a device to stabilize the flow when using the pump. Not sure, just a guess. But could any of you AS Guru's out there tell me just what this is ??? I winterize by blowing the lines using an air hose at the city water inlet. Does anything special need to be done with this or will it blow out with the rest of the system ??? After blowing I disconnect the
inlet / outlet lines at the pump.
Thanks all, See ya on the road sometime.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-16-2012, 08:59 AM   #2
SteveH's Avatar
Common Sense , Texas
I forget the exact name for it, but it's basically a pressure modulator to keep pump pulsations from the faucets....just like you assumed.
Don't believe you need to do anything with it when winterizing.
Old 11-16-2012, 09:54 AM   #3
retired USA/USAF
2001 30' Excella
Thanks Steve. Appreciate your help.
Bye-the-way, is Common Sense, Texas something similar to Normal, Ill. I certainly am in Abnormal, NJ and not sure if there is ANY common sense here. That's for sure.
Roger in NJ
TAC - NJ 18
Old 11-16-2012, 10:25 AM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
It sounds like an accumulator tank. They are pressurized, hence the Schrader valve, and provide an air cushion that smooths the water flow from the pump.
My submission or possibly misnamed places is Humble, Texas. Just doesn't sound right somehow.
Vaughan
Old 11-16-2012, 10:29 AM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I think that's why they pronounce it "uhmbull".
David
DKB_SATX is online now   Reply With Quote
Old 11-16-2012, 11:34 AM   #6
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
Somewhere in the manual should be the following, it's the Accumulator Tank used to smooth out pressure and reduce pump surging.
http://www.shurflo.com/files/RV-Inst...2-100_200_.pdf
Damon
damonbeals is offline   Reply With Quote
Old 11-16-2012, 12:09 PM   #7
retired USA/USAF
2001 30' Excella
I'm sure that if I read the manual it would have answered this question. But the manual is in the trailer parked at my son's house. Thanks all.
Hey Vaughn, do the make pie in Humble, Tx ?????
Roger in NJ
TAC - NJ 18
Old 11-16-2012, 02:00 PM   #8
SteveH's Avatar
You won't find "Common Sense, Texas" on the map. Just a little "thing" with me.
Old 11-17-2012, 07:11 AM   #9
retired USA/USAF
2001 30' Excella
That's the best place to live. Somewhere that nobody can find you unless you want to be found. I like that.
Roger in NJ
TAC - NJ 18
Old 11-17-2012, 08:43 AM   #10
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Humble, TX was probably named for an oil company, mergers turned it into part of Exxon/Mobil years ago.
mimiandrews is online now   Reply With Quote
Old 11-17-2012, 08:15 PM   #11
1983 34' Excella
1967 24' Tradewind
Images: 32
It was. I remember Humble Oil.
I still enjoy it, though.
On the other hand, there is Texico, New Mexico that has noting to do with Texico the oil company, which is from Beaumont.
Vaughan
