Old 06-06-2014, 05:33 PM   #1
Thiss's Avatar
1971 27' Overlander
Monmouth , Oregon
Slow Draining '71 Fresh Water
Hi all,
I have a super slow draining fresh water tank. Is this common, or do I need to pull the valve out and look it over?
Thank!
Thiss is offline   Reply With Quote
Old 06-06-2014, 05:50 PM   #2
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Mine has been that way since I drove it off the lot. Took a clear hose, connected it to the drain valve and blew air into the tank and it did drain faster. Seems to be some foreign matter in the tank that clogs the drainage.
tsunami is offline   Reply With Quote
Old 06-06-2014, 06:27 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Is it vented? The fresh tank on my TW drains very slowly unless I take the filler cap off.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 06-06-2014, 06:43 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
My '72 TW does drain a lot slower than the '67 GT I previously owned.
When I rebuilt the plumbing on the TW with a new pipes and valve it did not seem to have any effect.
I suspect it's due to how flat the tank is. Low "Water Column" provides low pressure. The GT tank is a lot taller.
Bruce. My GT had a relief cut thru the threads on the filler cap. Check to make sure it hasn't corroded closed.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 06-07-2014, 08:41 AM   #5
68 TWind's Avatar
1968 24' Tradewind
Thanks, for the tip. I'll check it. I recently added a vent tube to my tank and it fixed the slow drain problem. My tank is aftermaket and it had a place for an extra fitting. When I plumbed it I set it up so I can fill it when attached to city water. I would have to open the filler or the tank would pressurize, the vent tube fixed that. Also, I put a little silicone plumbers grease on the threads to prevent it from seizing (again) so the relief cut may well be clogged.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 06-07-2014, 09:13 AM   #6
r carl's Avatar
Lin , Ne
When I fill my freshwater tank I open the drain to clean it out. The pressure will force out algae and whatever. When the tank is about full I close the valve.
Draining fresh water tank on 2007 31' Classic au_ee 2006 - 2010 Classic (all lengths) 5 04-03-2011 05:17 PM
Draining the fresh water tank???? Joebanjo Plumbing - Systems & Fixtures 6 11-28-2010 08:30 AM
Draining the fresh water tank JDE10 Fresh Water Systems 1 08-01-2010 02:54 PM
Draining fresh water tank? FishHouse Fresh Water Systems 3 05-13-2010 01:59 PM
Draining Fresh Water Tank psundstrom Fresh Water Systems 2 10-15-2007 07:37 PM
