Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 07-15-2007, 11:39 PM   #1
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
shurflo water pump, which one?
i'm looking into the shurflo water pumps.
the first one is the whisper king which puts out 2 gallons a minute SHURflo Whisper King Demand Fresh Water Pump - Camping World
the second is the classis pump at 2.8 gallons a minute SHURflo Fresh Water Pump - Camping World
third is one is the extreme series which puts out 5.7 gallons a minute Extreme Series Smart Sensor 5.7 Water Pump - Camping World
couple of questions;
1. is the whisper king that much quieter and is the less output a good trade off?
2. do i need an accumulator tank?
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 07-16-2007, 12:46 AM   #2
GreatPumpkin's Avatar
Colville , Washington
Images: 70
I'm using the second option (Shurflo model 2088 12V 2.8gpm). It has worked great for us. I think I paid much less for it on eBay vs Campingworld.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 07-16-2007, 02:56 AM   #3
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English , Hampshire
Send a message via MSN to Moonstruck Send a message via Yahoo to Moonstruck
I would concur and bow to the superior knowledge of The Great Pumpkin!
2.8 GPM is quite enough where, in my opinion, it matters - a good shower!
Paid $ 160 for mine!
Marc
Silvertwinkie
Hampshire, UK
Moonstruck is offline   Reply With Quote
Old 08-12-2007, 08:23 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Has anyone purchased the Whisper King? Are you happy with it. Thanks...
Old 08-12-2007, 08:31 PM   #5
Retired.
. , At Large
We put one in our Argosy 20, it worked well for as long as we owned the trailer. AS far as I know, it is still working. 2.0 was enough for the little trailer, and as long as you aren't going to be using every faucet in the place at once, it should be fine for most users.
Old 08-12-2007, 08:45 PM   #6
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
We have used the Whisper King for awhile, works pretty good although we don't use it for showers. Just purchased another for the new project, I liked the old one so much. This one will be used for showers, hope it works.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 08-12-2007, 08:54 PM   #7
Retired.
. , At Large
It worked in ours for showers. With only a 30 gallon maximum for a water tank, I really didn't want a pump that could drain it in 6 minutes flat. We used the little flow restrictor nozzle to keep pressure up to a tolerable level.
Old 08-12-2007, 08:59 PM   #8
1964 26' Overlander
1977 25' Tradewind
One other thing about the Whisper King it works at more than a whisper. At least on our composite aluminum floor. I plan on mounting the new one one a plate and then Isolating the plate from the floor. Double isolation should quiet the King down to a whisper.
Peace
Gary
Old 08-12-2007, 09:02 PM   #9
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I have the Whisper King in my Sovereign and it seems like a quiet pump. If it ever goes bad I am looking at the Shurflow Smartsensor 4.0 as a replacement.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-12-2007, 09:12 PM   #10
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
The Shurflow 2.8 serves us very well. Good steady showers and fast toilet flushes. You probably would get a good price at one of the many discount RV suppliers online. Watch the Camoing World sales, however, if you are not in a hurry. Actually the 2.8 isn't that expensive.
Neil and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 08-12-2007, 10:46 PM   #11
krikles's Avatar
1965 17' Caravel
west hills , California
It's (2.8) currently around $56 or so at ppl....
I got mine thu them and am very pleased.
krikles is offline   Reply With Quote
Old 08-13-2007, 12:44 AM   #12
JDL
JDL's Avatar
2005 19' International CCD
T , Oregon
I tried the 4.0 GPM Shurflow Extreme Series Smart Sensor 4.0 Water Pump.
It leaked internally and would not hold pressure. So I returned it.
I went pack to using the classic 2.8 GPM. No more problems with vibration as I put isolation loops in the lines.
JDL is offline   Reply With Quote
Old 08-13-2007, 04:25 AM   #13
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
That's what I was thinking also - even with 50 gallons. We finally tackled the fresh water tank, new clear feed lines and new exterior fill door that matches the original from 71. Hit the tank with clorox and filled her up. Ahh nice work - no leaks all is well - oops the pump won't build pressure. It probably hasn't been used in 10 years or more.
Old 08-13-2007, 06:23 AM   #14
davidz71's Avatar
1986 25' Sovereign
Thanks JDL, I'll keep that in mind.
Craig
AIR #0078
3.73 rear end
Old 08-14-2007, 05:03 PM   #15
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Well, I bit the bullet and ordered the Whisper King - hope to install it this weekend. Also ordered a 10 gallon gas/electric water heater. Need to give credit to the supplier. Got free shipping and the best part - ordered this stuff Sunday evening - it arrived today.
Big Discount RV - Low Priced RV Parts & Accessories
Old 08-14-2007, 06:14 PM   #16
urbanfood's Avatar
Venice , California
great job ganglin. let us know how the install goes.
after reading everyones thoughts and ideas, i think i'm going to go with the classic 2.8.
david
Old 08-15-2007, 06:28 PM   #17
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Have to Admit This
Well the water pump that I mentioned above that wouldn't build pressure....
urr... ahh - well it seems I fired it up and watched the new clear lines I installed under the sink - nothing, no water movement. So I ordered the new one and actually read the directions.... figure out where this is going yet.
Instructions for the new one said make sure you open the faucets on the trailer so the new pump can evacuate the air out of the lines..... hummm maybe that's what I should have done with the old one. Sure enough - the old one works.
Still going to install the new one given the old one is noisy and cycles on for no reason at all. Anyway.... DUUUUUUHHHHHHHH
Old 08-15-2007, 06:55 PM   #18
1964 26' Overlander
1977 25' Tradewind
Look at it this way, it was old and it probably would fail when you needed it most. Or only the newest and best for my baby. Or by changing to a new pump you you avoided a Flailing Duframus. Not many people could see that one comming.
Peace
Gary
Old 08-15-2007, 08:05 PM   #19
Retired.
. , At Large
I am sure I would receive one of those if our water pump failed while my wife was in the shower, with shampoo in her hair...
Old 08-16-2007, 04:29 AM   #20
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I don't know what a Flailing Duframus is but I'm at least smart enough to know it ain't something I ever want....
pump not working... Chuck Water Heaters, Filters & Pumps 23 05-16-2007 09:44 AM
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 08:28 AM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Water filter system 53flyingcloud Our Community 2 07-05-2002 04:43 PM
