Old 08-18-2007, 09:13 PM   #1
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
shurflo city water inlet
will this shurflo city water inlet work for my flying cloud? it's got a built in pressure regulator, is that what i need? it also looks like it has a built in check valve. am i reading that right?
Water Mount Pressure Regulator (65 PSI)
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 08-18-2007, 11:12 PM   #2
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Looks good to go David. It's got a built in pressure regulator, AND the backflow prevention.
All Water Entries contain an internal backflow preventer to stop reverse flow through the unit when the potable water pump is used.
However, interesting note: further reading says
Use at least 1 ft of flexible high pressure tubing...must not be connected directly to plastic or rigid pipe.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 08-19-2007, 06:45 AM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Looks Familure
That is what is on my 2003 CCD - Airstream is using it today.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-19-2007, 03:25 PM   #4
urbanfood's Avatar
Venice , California
great news. i'm going to order it today.
david
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
City water 53flyingcloud Fresh Water Systems 2 07-11-2002 12:08 AM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
