Old 07-23-2016, 07:18 PM   #1
KYAirstream's Avatar
Northeastern , Kentucky
Shurflo Accumulator
Does anyone know what the optimal PSI is for the small Shurflo accumulator. It says max charge 30psi, which is what I have it set at. I can't tell any difference in how the water pump runs.
KYAirstream is offline   Reply With Quote
Old 07-23-2016, 08:08 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I think mine is at 25. It was an immediate difference! Is your oump adjistable?
Where did you insert the accumulator?
I put mine in a dead end "t" right after the pump.
Old 07-23-2016, 08:41 PM   #3
Mine is right after the pump. I have the water line passing through the accumulator. What sort of difference did you notice?
Old 07-23-2016, 08:44 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Ours is at 30 psi, mounted under the bath sink and in the cold water line.
Doug and Cheryl
Old 08-02-2016, 08:55 AM   #5
DarrellT's Avatar
Longview , Texas
We've got a 2017 FC26 on the way this month. Should we assume this is an item we should install ?
Darrell
DarrellT is offline   Reply With Quote
Old 08-02-2016, 09:38 AM   #6
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
According to the instructions I believe ours is set around 20 to 25 psi.
http://legacy.shurflo.com/pages/Food.../911-378-P.pdf
The accumulator has resulted in quieter plumbing, more consistent water pressure - good for showers, dish washing etc....and gives some expansion in the plumbing system for hot water expansion or hydraulic surges when hooked to city water.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 08-02-2016, 10:27 AM   #7
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Where do you have yours hooked up?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 08-02-2016, 11:16 AM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
I installed mine more than 10 years ago and don't ever remember pressurizing it. I blow the system down when winterizing and thus the chamber is empty when I fill the water in the spring.
It has always worked well as far as extending to run time of the pump and the flow time before the pump restarts. Does what i bought it for.
2004 Excursion 4x4
What size Accumulator? '07 Bambi 19' Phantom Fresh Water Systems 10 08-21-2007 08:56 AM
New Water Pump or Accumulator Al - K4GLU Water Heaters, Filters & Pumps 4 08-15-2007 09:45 AM
Why no accumulator? Roger S Fresh Water Systems 29 08-09-2007 06:30 PM
Accumulator Tank silversled Waste Systems, Tanks & Totes 16 02-01-2007 08:32 PM
ShurFlo Accumulator?!? SilverToy Water Heaters, Filters & Pumps 6 04-19-2005 10:07 PM
