Old 10-21-2019, 07:39 AM   #1
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
Shur Flo City Inlet
Anyone ever replace the screw on fitting with a flexible line or other product? My fitting is not sealing tight and has small drip leak. I took off and reattached - no success. Iím on the road and looking at options on a non travel day. Photo of fitting Iím looking at options on repair/replace
Cispook is offline   Reply With Quote
Old 10-21-2019, 08:02 AM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Need a new swivel seal... Iíd use a bit of plumbers tape too for good measure...
https://www.amazon.com/gp/aw/d/B0006...b_b_asin_title
I carry a bag of these with me in the trailer....
wulfraat is offline   Reply With Quote
Old 10-21-2019, 08:17 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Is the leak at the PEX crimp ring? That's where I see water beads (I think).
If you have the tool, you might try to tighten the ring.
If it is the PEX fitting that is bad, replace it.
I've never added a flexible pipe at that location. If you do be careful to not create a loop that will hold water. That area is notorious for freezing.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 10-21-2019, 08:20 AM   #4
Cispook's Avatar
Chillicothe , Ohio
Didnít realize there was a seal in the fitting. Iíll relook-regards
Old 10-21-2019, 08:22 AM   #5
Cispook's Avatar
Chillicothe , Ohio
Nope - I checked the fitting clamp and it isnít leaking. Thanks
Old 10-21-2019, 10:15 AM   #6
2013 28' Flying Cloud
Penn Yan , New York
Water leak
Are u sure itís not the city water pressure limiter? Over time they go bad. They are easy to replace.
If you have to change the fitting you can get them at Loweís. You will have to buy a tool there also to install the clamps. I would pull the pressure regulator from outside and pull the line out of the trailer. There is usually enough slack in the line to allow you to do this.
Have fun.
delrossa is offline   Reply With Quote
Old 10-21-2019, 12:02 PM   #7
1989 25' Excella
Hershey , Pennsylvania
Images: 13
I had a slow drip on mine. Couldn't get it to stop. I finally took ik out of the trailer and that's when I discovered a hairline crack in the body, probably caused by freezing. Had to drive 50 miles each way to get a replacement. The good news is that they are easy to change. Good luck with it!
89Excella is offline   Reply With Quote
Old 10-21-2019, 01:12 PM   #8
Cispook's Avatar
Chillicothe , Ohio
It was the fitting. RV parrís store here sold me a pex push fitting with flared connector to replace the old one. Great on the road repair. Click image for larger version
Shur Flo Water Pump- SILENT? Ray Eklund Fresh Water Systems 59 Yesterday 07:37 PM
Shur-Flo gasket material DaveMc Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 05-26-2018 06:32 PM
Confused! Wiring in a Shur-Flo vent fan to a '66 Carvelle awolff Electrical - Systems, Generators, Batteries & Solar 3 07-12-2013 12:13 AM
Shur-Flo pump is Too Loud star kitty Fresh Water Systems 19 09-28-2011 11:20 AM
Shur-flo water pump cycles on and off steverino Plumbing - Systems & Fixtures 11 05-29-2011 02:51 PM
