Old 06-10-2004, 07:28 PM   #15
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
53FLYINGCLOUD, I routinely use a pressure regulator at the connection to the water source since I have three of them from my previous unit. I have one attached to each of my hoses along with quick disconects on each hose. I use them in spite of the fact that my unit has a built in pressure regulator also, but your advice is sound. I use them to help keep my hoses from bursting or being damaged.
GStephens
GStephens is offline   Reply With Quote
Old 06-21-2004, 12:55 AM   #16
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Thanks . . .
Mark (MW64OVERLANDER),
I just wanted to close the loop. I received the Sloan Vacuum Breaker rebuild kit from Hirsh on Friday and installed it on Saturday. It works great. One more item off the list, . . . many, many more to go. But were goin' to the International anyway.
Joe
66Overlander is offline   Reply With Quote
Old 06-21-2004, 06:34 AM   #17
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up Kewl~
GStephens
Great~!!
Sounds like you've been around the block more than once~!
I figure even tho you & I know it..we never sure if someone else is "reading" this for the first time..they picks up on it and, saves them from having problems..
Good luck`
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-08-2004, 09:22 AM   #18
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
I retrieved my part which generated my original question on this thread from the dealer with whom I left it the other day. He had not thrown it away.
With the aid of a magnifying glass, I found that my part has the following stamped into its side. "Watsons Vacuum Breaker 4900 v" I suppose that answers my original question. It is a vacuum breaker.
Does anyone have a source for either a replacement of this vacuum breaker or for a rebuild kit like the one mentioned above for the the Sloan part? What vacuum breakers, if used, are used on newer units?
GStephens
Old 07-08-2004, 09:41 AM   #19
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
You might look at this vendor's offerings. Scroll down to vacuum breakers near the bottom of the page.
Tom
Old 07-08-2004, 09:56 AM   #20
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
Thanks tcwilliams. Gosh you are fast. My part appears to look just like the volume control part no. 477, but I suppose what I need is the vacuum breaker part no. 4900 that appears just below at the very bottom of the page. In fact, I notice that it has the same 4900 part number on it. Can't tell if it is the same manufacturer, but that doesn't matter to me. Thanks again.
You know this is REALLY something. I found out a solution to my problem here on the forum in less than five minutes that contact with an Airstream dealer and his contact with the factory could not resolve. To me, that speaks volumes. Thanks again tcwilliams and all of the other forum members who stand by ready to help.
GStephens
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Followup to valve stem failure dtbw Wheels, Hubs & Bearings 0 10-29-2003 08:40 AM
Ugh! shower leak detected. mcostanzo Sinks, Showers & Toilets 1 10-03-2003 10:33 AM
Sagging Shower w9det 2001 Safari 1 09-12-2003 01:28 PM
