Old 10-13-2005, 05:54 AM   #1
2003 22' International
Clarkston , Michigan
Shower Pressure
I have an '03 Int'l CCD 22'. Not much pressure in the shower mode in the wet bath. Kitchen and toilet pressures are OK. How do I increas the pressure at the bath sink/shower fixture?
Skinner1 is offline   Reply With Quote
Old 10-13-2005, 06:10 AM   #2
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Hi, Skinner and welcome to the Forums! I'm sure you'll get some good advice... the first thing I'd check would be to take the shower head off and make sure it doesn't have any 'stuff' in it. Sometimes flashing from plastic, or small pebbles from the water supply make their way into the fixtures. I've cleaned lots of small rocks and other bits of 'stuff' out of faucet screens over the years. You'd be surprised to find out how little 'stuff' it takes to reduce the water flow.
Roger
Old 10-13-2005, 06:15 AM   #3
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Ooh, Ooh, I know
If this is your first RV with a shower head, it is common to not realize that the button on the side must be pressed all the way into the on position.
I think every one does this when they are rookies, ( I did ). I have seen this several times.
You may have some debris in there but I bet that the button is somewhat pressed in the middle position.
smily is offline   Reply With Quote
Old 10-13-2005, 12:02 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
We had this same issue in our 2003 Bambi. There was clearly a hardware problem with it. I never got too far into it since we upgraded to a 2004 Safari. It didn't have the problem.
Old 10-13-2005, 12:57 PM   #5
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
We were also not satisfied with the shower pressure in our 02 Bambi - we too took it apart to check for debris but found none. I assumed there was a built in pressure reducer that was engineered more for city water pressure than the lower pressure of an RV water pump. I replaced the shower head with an Oxygenics unit from Camper World ( http://www.campingworld.com/browse/s...28026&src=SRQB ) - this made all the difference in the world - the shower head lives up to its advertised expectations. There is no shut-off on the Oxygenics head but the faucet shut-off in the shower is so easy to use that this has not been a problem.
I put the original unit in our house shower - and it works great.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 10-15-2005, 03:55 PM   #6
Skinner's shower pressure
Thanks, I know the button is depressed, so that's not the problem. I'll look for debris, but it seems the pressure is too low to keep the shower button on the "shower" setting. Any other advice would be great. I'll check out the Oxygenics unit.
Thanks again.
Skinner1
Old 10-15-2005, 06:52 PM   #7
wbrownrr's Avatar
2002 22' International CCD
San Luis Obispo , California
We used this simple fix for the shower head in our 2002 22' CCD per a suggestion from Pahaska (search this forum for his posts). We removed the perforated section of the shower nozzle and used a drop of Gorrilla Glue (from the inside) on every third hole, then reassembled the whole thing after the glue had dried. This, in effect, increases the water pressure and results in a strong spray when hooked up to shore water or when using the water pump. Simple and easy, and it works! Ya gotta like that.
wbrownrr is offline   Reply With Quote
Shower stall walls 53flyingcloud Upholstery, Blinds, Walls & Interior Finishes 11 04-07-2016 06:25 AM
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Shower head problems Pahaska Our Community 25 08-26-2002 10:43 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
