Old 07-22-2008, 04:53 AM   #1
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Shark-bite Pex components.
Hi all;
Being way past my scheduled date of completing my Argosy, we had no time to test our plumbing system before departing on maiden voyage on July 11th. The time allowed for testing was consumed by repairing of a crack in blue tank. Having my plumber friend's assurance that brass Shark Bite type Pex fittings never leak, we set of for Promised Land State Park in Pa.
After arrival and set up, I have turned on my Max Sensor which refused to stop pumping. Thinking that the hot water tank was filling up, I proceeded to bleed air from all spigots. By the time I have realized what is going on water was everywhere. It turned out that five out of twenty four connections leaked. We wound up shutting the system down, and upon my return following Monday I have called my plumber buddy. According to him during the initial phone conversation I have made mistakes inserting the tubing into connectors. Forty five minutes later he arrived ready to expose my mistakes. Two hours later he still had same number of leaks. After two hours I requested that they are replaced with crimp on connectors. While all water was cleaned up, and although my aluminum clad floor did not absorb any moisture, my level of embarrassment at the camp site was enough to ruin my weekend. Now most of connections are crimped. Remaining eight will be changed soon.
I want this post to serve as a warning that brass Shark Bite fittings do leak despite any warranties. Now with the system tested, we are off on July 25th. back to Promised Land State Park to do some catch and release fishing. Thanks, "Boatdoc"
P.S. Our Arg tows steady as in a dream.
boatdoc is offline   Reply With Quote
Old 07-22-2008, 06:46 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Thanks for the info, as I was considering using them. I think I will look into Swagelok instead.
Old 07-22-2008, 08:16 AM   #3
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
boatdoc,
Sounds like a dreadful experience. Hopefully the grand time you have on your next trip will wash away the bad memory.
Did you plumber friend has any explanation for the leaks? Surely he was surprised and chagrined.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 07-22-2008, 08:18 AM   #4
mrmossyone's Avatar
1975 Argosy 24
Collierville , Tennessee
Mine on PVC/CPVC haven't leaked but I'll keep an eye on them. My brother is a plumber and he loves them. You do have to be careful and slide them in to the correct depth.
Different strokes for different folks!
I never learned from a man who agreed with me.
Heinlein
mrmossyone is offline   Reply With Quote
Old 07-22-2008, 10:13 AM   #5
lewster's Avatar
Naples, FL , Hood River, OR
WOW!
This is an eye-opener for sure!
I have been using Sea-Tech fittings for 4 years now and haven't had a failure. I have had a couple of leaks, which were traced to insufficient insertion of the tubing into the fitting, but the leaks stopped immediately when the tubing was inserted properly.
I do know that any lateral pressure or side-ways strain on the tubing (as not being inserted squarely into the fittings) will cause them to weep, which requires you to have a clean, perpendicular entry into the fitting. I clamp the tubing near the fittings to accomplish this.
Something to watch in the future
Old 07-22-2008, 10:49 AM   #6
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Boatdoc,
What brand and type of PEX did you use?
Considering the shear number of failures and the inability of your plumber to get them to stop leaking, I would assume that the problem is caused by a dimensional incompatibility of the PEX and the fittings.
The Cash-Acme site states that the Shark-bite fittings will only work with PEX that meets ASTM F876, CSA B137.5 specification.
Sorry to hear of your difficulties, that would ruin my weekend too.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 07-22-2008, 05:23 PM   #7
boatdoc's Avatar
1973 Argosy 26
Originally Posted by byamcaravanner View Post
Boatdoc,
Hi Steve; Tubing is ZURN CL/TD-ASTM F876/F877-B137.5UPC-Hot/Cold. Fittings are CASH ACME 1/2 CU/CPVC/PexcUPCIGC188. There was very little of linear misalignment in tubing, because the tubing is naturally coiled. This in itself will cause some directional force on the fitting. Since the tubing comes coiled the manufacture should have designed the fittings with this in mind. Another plumber told me that unless high water pressure hits the fitting instantly the "O" rings may seep at lower pressures and prevent them from fully sealing the connection. As I stated previously the tubing was inserted properly. I will replace the rest of them with crimp on connectors in the near future, but from this upcoming Friday I am going camping. Thanks for your comment Steve. Regards, "Boatdoc"
Old 07-22-2008, 06:15 PM   #8
1967 28' Ambassador
1970 29' Ambassador
Thanks for the info... I'm glad I opted to spend the bucks on the crimper and the crimp ringes rather than buy the shark-bites and avoid the expense of the crimper. I do not relish the idea of having to re-do what I have just re-done.
Good Luck! ...and relax doubly hard on your next trip.
Steve & the crew
Old 07-22-2008, 06:59 PM   #9
trevisgardne's Avatar
1973 31' Sovereign
Maryville , Tennessee
I have had no problem with Sea-Tech fittings. I probably used 25 of them to replumb my entire trailer.
trevisgardne is offline   Reply With Quote
Old 07-22-2008, 07:58 PM   #10
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
I have replaced all my copper with blue/red pex and shark-bite fittings.
So far so good....
Sorry to hear about the leaks.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 07-22-2008, 09:01 PM   #11
1972 23' Safari
Tallassee , Alabama
I don't know which fitting I have but I haven't had any problems with them. These are the fittings that are all plastic and go inside the pipe and have a twist on ring that deforms the pipe and clamps everything together. I tighten them down with a Channel Lock style wrench making sure I don't deform anything, just using up all the threads. The dealer told me to crank them down until they squeak, I go a bit further. I also make sure that the cuts are clean.
Related to the crimp style, we did have a nasty event with our new house. Apparently the plumber's crimper went out of calibration while finishing the plumbing and one of the outside faucets decided to leak. We didn't find it for about 2 months, by then the closet had moldy carpeting and a lot of drywall damage.
My approach with the PEX is to make sure the fittings don't have any lateral pressure on them by anchoring the PEX tubing to whatever I can. I have also only used tubing that says PEX on it. For holding the tubes in place, I use the official plastic clamps, I would worry about abrasion with metal clamps. I also charge the system using city water before I close it up and let it sit for a day or so and check for leaks during the test. (if you can't tell, I have had really bad luck with plumbing and the AS project hasn't been an exception).
So my recommendation is to test it before proceeding. If you use the crimps, invest in the gauge and make sure everything is meeting specification.
Tom Bray
Tom Bray is offline   Reply With Quote
Old 07-22-2008, 10:38 PM   #12
lewster's Avatar
If you want to test your water system with no potential for water damage.....you can do a leak-down test using pressurized air. I usually seal any outlets, add an end cap with a Shrader valve and pump up the system with air to whatever the system's weakest component specifies (generally around 65 PSI).
I also have a gizmo that attaches to the Shrader valve that has a large dial pressure gauge on it and wait 24 hours to see if the pressure has dropped. If it has......you got a leak, and I then go around the system with soapy water solution (just like testing an LP line) to find the leak. No water leaks this way........just air
Old 08-01-2008, 07:51 PM   #13
MTsafari's Avatar
1970 23' Safari
Columbia Falls , Montana
Hi Lew,
I need to recheck my plumbing system, and your air check method will be ideal.
I recently had a water system check on my 23 ft '70 Safari at a local RV dealer. I was told that there were a couple of easy to fix leaks and a new hot water heater was needed. After installation of the water heater they charged up the system and are now saying numerous leaks are appearing ($1200 worth).
In your opinion, would the leaks have been apparent even without the installation of a new water heater? Seems like the RV dealer would have had a better way to test for leaks before beginning the installation of new parts. Or would the leaks not have appeared without on operable water heater?
Tim
MTsafari is offline   Reply With Quote
Old 08-01-2008, 09:34 PM   #14
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
My Sarkbite fittings are great. However, I did NOT use the PEX that came coiled. I used the straight stuff. There is a little give to it to manuever by some obstales but for angled corners I used the Sharkbite. Perhaps the 'give' in the coiled PPEX product isn't making for a solid connections.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Shark Hide protectant ckeysor Clearcoat, Exterior Paint & Trim 56 08-24-2014 11:50 AM
About To Bite The Silver Bullet strohmdl Classic Motorhomes 9 07-28-2008 04:14 PM
The other ebay 20' (shark cage) secnwind Argosy Motorhomes 8 08-18-2007 10:20 AM
Steering components shocker bkahler Mechanics Corner - Engines, Transmission & More... 2 06-14-2007 04:54 AM
Parts source for 345 rear suspension components? Honkity Hank Classic Motorhomes 3 07-17-2006 12:56 PM
