Old 04-22-2015, 12:37 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Sanitizing fresh water systems
I have a new to me AS. I would like to sanitize the fresh water system. The manual says 1 teaspoon of Clorox for every 10 gallons as a regular maintenance treatment.
Would some kind of initial shock treatment be in order? How much Chlorox or other chemicals should I use?
Does anyone use a chlorine test kit regularly on their water?
Old 04-22-2015, 12:52 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
When I first goy my new to me trailer I was informed that the tank had been empty for over a year. I did feel a shock treatment was in order. I mixed two cups of bleach with a gallon of water and added it to the tank. I then filled the tank to overflowing and let it sit over night. The the next day I drained the tank by running water out the sink and shower taps and refilled. Drained it again and refilled. I use no sanitizer in the tank. The water I put in my tank already has clorine in it. It gets filtered as it goes in and there is a filter at the kitchen sink for drinking purposes. I do not us a test kit.
MICHAEL
Old 04-22-2015, 01:07 PM   #3
SteveH's Avatar
Common Sense , Texas
A recent thread on the subject: http://www.airforums.com/forums/f458...nk-133557.html
Regards,
Steve
Old 04-22-2015, 01:27 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I don't know where that came from.
My manual says that to sanitize the fresh tank and plumbing, use 0.13 ounces unscented Clorox bleach per gallon; for me that's about 4 ounces for a 32-gallon capacity (including water heater). Let it sit for about four hours, then flush with clean water.
EPA and CDC guidance for emergency treatment of drinking water says you should use one teaspoon of Clorox per gallon of drinking water. One teaspoon per ten gallons is way too little to kill any microorganisms that might have gotten into the water, and is a waste of perfectly good Clorox.
But as long as you fill the fresh tank from a trusted municipal source using a clean hose and sanitize the plumbing as directed when you un-winterize and again after any plumbing repairs, you don't need to add Clorox to the drinking water at all.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-22-2015, 02:02 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Household bleach is 5.25% sodium hypochlorite and has 50,000 ppm available chlorine.
1 teaspoon (1/6 oz) per 10 gallons will give you 6.5 ppm free chlorine assuming that there is minimal organic matter and the pH of the water is near neutral.
50000 ppm * 1 tsp * 1/6 oz/tsp / 128 oz/gal / 10 gal = 6.51 ppm
I've been using 1 mL per gallon which gives around 12 ppm.
The CDC and other authorities recommend a minimum residual chlorine level of 0.5 ppm for water storage and distribution systems. The WHO recommendation for open storage is 0.2 ppm - 2 ppm, with the maximum being set because water exceeding 2 ppm residual chlorine will have an objectionable odor.
The higher treatment rates aren't necessary unless:
1) the water is extremely cold, reducing the activity of the chlorine
2) contact times are extremely short (under 10 minutes)
3) organic material or metals are present in the water, so that a good deal of chlorine is bound to these compounds
Excessive rates will cause progressive damage to plumbing components, particularly washers and seals.
Old 04-22-2015, 03:34 PM   #6
Thank you. It appears that the document I downloaded from EPA three years ago is off by a decimal point. That's Government for you!
Since Jammer posted his info, I went back to the EPA web page, and downloaded a newer copy of their guidelines, which say 1/8 teaspoon per gallon. A teaspoon per ten gallons isn't so far off base after all.
I stand corrected.
WBCCI #1105
TAC LA-4
Old 04-30-2015, 02:59 PM   #7
2015 30' International
FREDERICK , Maryland
In the process of sanitizing my 54 gallon tank, I have noticed that though it only took me 17 minutes to fill, it took about 2 hours to drain out through the small valve. That seems like quite a long time. Is that normal?
Doc Foster is offline   Reply With Quote
Old 04-30-2015, 03:02 PM   #8
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Yes, that's pretty typical. No worries.
Bob Martel
WBCCI# 5766
'78 Argosy Minuet 7.3 rear bath black water and gray water systems cutndried All Argosy Trailers 12 08-10-2017 03:12 PM
Sanitizing Potable Water tank pond Winterizing, Storage, Carports & Covers 20 04-30-2015 08:17 PM
Sanitizing Fresh Water, Making a Bomb? HeadWest Fresh Water Systems 11 06-25-2013 11:07 AM
Sanitizing the water system zimbop Fresh Water Systems 13 02-11-2013 08:36 AM
Sanitizing Water System bike_addict LP Gas, Piping, Tanks & Regulators 27 10-12-2011 04:47 PM
