Old 08-26-2016, 07:54 AM   #1
angellhill's Avatar
1978 Argosy Minuet 6.7 Metre
Burlington Flats , New York
Sand in fresh water tank
We recently stayed at a state campground and water from the campground well brought sand into the fresh water tank. How can we remove the sand from the tank?
angellhill is offline   Reply With Quote
Old 08-26-2016, 07:59 AM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
You could check your water pump suction line, mine has a filter on it, you may need to improve it a bit.
sgschwend is offline   Reply With Quote
Old 08-26-2016, 08:00 AM   #3
2014 25' FB International
Metuchen , New Jersey
I was going to suggest to fill up the tank and then open the drain valve, but now I'm not so sure if the valve is large enough to allow the sand to pass through without clogging it.
Did you use a water filter when filling up?
GenXair is offline   Reply With Quote
Old 08-26-2016, 08:01 AM   #4
Long Island , New York
You might have to remove the drain valve assembly IMO, if possible (to get a larger opening), and then flush flush flush it out. Is your tank original? Any chance there is a hidden drain point you can get to if you remove the exterior underbody aluminum pan?
OTRA15 is online now   Reply With Quote
Old 08-26-2016, 08:04 AM   #5
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
That's why we always use an inline filter. I got tired of cleaning the aerator screens in the faucets.
2012 Dodge Durango Hemi/AWD
Old 08-26-2016, 08:16 AM   #6
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
That happens with rural water. It's not dangerous to your health, though may mess with your teeth.
In general, though, your plumbing should have a sediment strainer located between the pump and the water tank. This keeps tiny bits from making their way into the pump itself, causing it to fail to maintain pressure within your system. Here's a common one:
As for the sediment that's in your tank, well, just leave it there.
Lynn
WBCCI 21043
Old 08-26-2016, 08:45 AM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Sand can get into the water in any water system, well or municipal.
Most fresh water tanks have some accumulation over time, unless all water is filtered.
Alan
Old 08-26-2016, 08:53 AM   #8
Lily&Me's Avatar
Normal , Illinois
If you run water into your sink and/or shower when dumping your tanks, you will see the sand slide right out.
I always have this problem when camped on or near beaches.
I think a lot of this sand you see is airborne, landing on surfaces things that get washed...ultimately ending up in your grey tank.
Maggie
Old 08-26-2016, 09:58 AM   #9
Whoops! -- the OP's sand is in the fresh water tank.
Tanks!
Peter
Old 08-26-2016, 10:04 AM   #10
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Future preventative solution here, excellant company to do business with.
https://www.rvwaterfilterstore.com/A...ingASystem.htm
MICHAEL
Old 08-26-2016, 11:39 AM   #11
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
There should be a large drain plug under an access panel in the pan that covers your fresh water tank. Remove the access panel, unscrew the large plug, I think it's either a 1" or 1 1/4" plug....
In the future get yourself an inline filter and put on the water spigot at the campground...
Good luck
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 08-26-2016, 11:45 AM   #12
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Good luck
Larry
X2
I had to drain ours....POI use the DW's hair dryer to soften the sealant.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-26-2016, 12:43 PM   #13
1976 31' Sovereign
Oswego , Illinois
Smile
I don't think they put bottom drain in 76 Argosy models as my 76 Sovereign does not have drain, only way to drain is with water pump, this is another great engineering job by AS. Don't reply that I don't no what I'm talking about just check owners manual and service manual, you won't find valve listed. I pur. this 1976 new in 1977 [still own] so I'm well versed in this trailer having done all repairs and upkeep. Except for 2 panel replacements.
Old 08-26-2016, 01:53 PM   #14
1976 31' Sovereign
Oswego , Illinois
There is also another thread draining fresh water tanks that I found after posting above.
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
To sand or not to sand ? jonplayers Cleaning, Stripping & Polishing 12 11-17-2013 03:41 PM
October Great Sand Dunes & Senic Rail Rally? Boondocker Forum Rallies & Meet Ups 12 03-06-2006 01:07 PM
Great Sand Dunes tips? rfield54 Our Community 6 06-11-2005 05:26 AM
