Old 08-26-2016, 04:02 PM   #15
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
Drain water line
My 77 Argosy had sand and dirt in the bottom of the fresh water tank when I got it and the tank drain was clogged and inoperable. I disconnected the water line to the pump, cut the end off of an old water hose and hooked it onto the pump outlet with a hose clamp and ran it out the door to the street. The pump hose outlet is also bigger than the drain tube on mine. I then filled the tank half full and drained it several times until the sand was gone. Since there isn't a shutoff on the water hose I just draped it over the propane tank so it was higher than the tank while I refilled. Later I replaced the tank drain valve
rvb is offline   Reply With Quote
Old 08-26-2016, 05:46 PM   #16
Lily&Me's Avatar
Normal , Illinois
Originally Posted by OTRA15 View Post
Whoops! -- the OP's sand is in the fresh water tank.
Tanks!
Peter
Maybe I didn't understand, but what I meant to say was that it will all end up in the grey tank eventually, and can be flushed out.
Won't it???
Maggie
Old 08-26-2016, 06:08 PM   #17
2007 22' International CCD
The problem is that if you don't stir up the sand and dirt in the bottom of the fresh tank, it will just stay in there. Running it through the plumbing with the pump won't take it out that well, and risks clogging faucets and shower heads.
Need a large diameter drain valve and a lot of water flow to get it out. That's why filling the fresh tank through an external sediment filter is a good idea. Keep it out before it gets to the tank.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 08-26-2016, 06:23 PM   #18
Lily&Me's Avatar
Normal , Illinois
Okay.
Silly me.
Maggie
Old 08-27-2016, 06:11 AM   #19
angellhill's Avatar
1978 Argosy Minuet 6.7 Metre
Burlington Flats , New York
Yes, on the hose and the water pump, but the screen allowed the small particles through.
angellhill is offline   Reply With Quote
Old 08-27-2016, 06:16 AM   #20
angellhill's Avatar
I have one of these but the fine sand still got through it.
Old 08-27-2016, 06:17 AM   #21
angellhill's Avatar
I had the sediment filter.
Old 08-27-2016, 06:26 AM   #22
angellhill's Avatar
Thank you everybody. I think I'll put in a threaded 4" bulkhead plate on the top of the tank to give me shop vac access.
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
To sand or not to sand ? jonplayers Cleaning, Stripping & Polishing 12 11-17-2013 03:41 PM
October Great Sand Dunes & Senic Rail Rally? Boondocker Forum Rallies & Meet Ups 12 03-06-2006 01:07 PM
Great Sand Dunes tips? rfield54 Our Community 6 06-11-2005 05:26 AM
