Old 05-12-2014, 06:55 AM   #1
2012 27' FB Classic
Christiansburg , Virginia
Restricted water flow
Hello air forum. Being new to the forum I step off into the my introduction. I am second owner of an airstream. My first was an '03 25SS, and my current unit is a '12 27 Classic. This is my first spring start and as I began the dewinterizing process - bleaching the water system and flushing I encountered a problem. The toilet, shower and outside shower all work fine, however the bath sink will not flow, and the kitchen sink flows very. Slow at 1/4 flow. I at first ran the system through the pump to sterilize everything but when that failed I pulled the manual and found no plumbing schematic. I tripped the pop off valve and the hot water heater is full. I connected city water but no change. I opened the bypass valve to curb water, no change.
The faucets are not sputtering, just not flowing or slow? If anyone has experience in this or an recommendation on how to proceed I would greatly appreciate the assistance.
I am new to the forum, so I greatly look forward to the fellowship. I am soon to switch from a vacation/weekend camper to doing some travel. Thanks
Two4theroad is offline   Reply With Quote
Old 05-12-2014, 07:58 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Welcome!
Try checking the faucet strainers for debris. We had a similar problem this spring, the strainers were plugged solid. Once we removed them, the water flowed without problem.
Kay
Old 05-12-2014, 09:28 AM   #3
Tltulsa's Avatar
1992 29' Excella
Tulsa , Oklahoma
i second that. I have to take mine off every few trips...probably have a decent amount of sediment in the lines. Once the strainer is cleaned, works like magic.
1992 Excella Classic 29'
...2013 Chevy 2500 HD, 6.0 Gasser
Tltulsa is offline   Reply With Quote
Old 05-13-2014, 04:16 PM   #4
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
A fellow Virginian will "third" that suggestion to clear faucet heads; with some small take down and put back work you should be fine.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 05-13-2014, 06:50 PM   #5
2012 27' FB Classic
Thanks much, it worked. Both were filled with crud. The water flows gears now.
Old 05-23-2014, 12:35 PM   #6
Tltulsa's Avatar
1992 29' Excella
Tulsa , Oklahoma
Nice
No water flow after hooking to city water Grevers911 Fresh Water Systems 8 06-23-2013 10:08 PM
Your card has been restricted TomW On The Road... 20 10-18-2008 12:06 PM
city water won't flow..help! AirSpleen Fresh Water Systems 9 08-20-2006 05:39 PM
Water flow question... Sneakinup Waste Systems, Tanks & Totes 1 05-19-2004 06:20 PM
No water flow Michael W Plumbing - Systems & Fixtures 4 10-12-2003 08:26 PM
