Old 02-15-2009, 05:36 PM   #1
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Replacing the low point water drain valves
My trailer is safely in my sisters driveway leaking fresh water onto the driveway. The low point (hot and cold) drains are leaking. I do not like "butterfly" valve type valve since the "wings" are pressed on and prone to slipage. Has anyone replaced them with ball valves or some other type that will work better?
Michelle TAC MT-0
Sarah, Snowball
Old 02-15-2009, 07:46 PM   #2
Campaz's Avatar
1987 23' Sovereign
Tucson , Arizona
I recently replaced mine with Shark Bite brand ball valves. If you're not familiar with them, they simply "plug'" in. In other words you cut your Pex water lines so that an inch of it inserts into the Shark Bite ball valve, instructions enclosed. You're done!! I am amazed they don't leak,... but they don't. They are pricey, about 20 bucks apiece. Quick, easy and seem to be a quality item. Easy to operate with a nice lever.
Rick
Rick
WBCCI# 4652
Four Corners Unit
Campaz is offline   Reply With Quote
Old 02-16-2009, 07:11 AM   #3
Rick
I have to run some errands today. I will look for them at the hardware store.
Thanks.
Michelle TAC MT-0
Sarah, Snowball
Old 02-17-2009, 10:46 AM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Good tip on the low point valves - how about the fresh water drain valve? That one worries me every time I use is - cheap nylon will break easily.
Pat
pmclemore is offline   Reply With Quote
Old 02-17-2009, 11:32 AM   #5
Pat
Pat,
I have had that one freeze. No the valve but the water directly behind the valve froze. She did not drain until I stopped and the heat was raised up to 70 in the trailer.
Michelle TAC MT-0
Sarah, Snowball
drain, low point, valve, water
front low point drains, 19' int'l ericwarren Winterizing, Storage, Carports & Covers 3 12-18-2008 02:58 PM
Low point drains runningbarre Winterizing, Storage, Carports & Covers 5 09-25-2008 06:07 AM
Failure of low point drain valve? desidou Fresh Water Systems 8 12-24-2006 08:29 AM
'78 20' Minuet repair question: grey/black water drain valves Van All Argosy Trailers 4 01-06-2004 09:40 AM
where are water drain valves/1990 Excella 32' ? femuse Plumbing - Systems & Fixtures 3 04-28-2003 09:13 AM
