Old 05-07-2014, 05:29 AM   #15
aquinob's Avatar
Portsmouth , Virginia
Originally Posted by RankAm View Post
Bob, could you please explain why you thought it necessary to install the boat fitting? Thanks, Hank
Hank
Both are boat fittings, but I think you are referring to the small vent on the bottom. The thought is that it is possible for the tank to backfill from the connection that the pump has to make to the main water supply. There is an isolation valve and should be checkvalve protected from water going back into the tank through the pump.
Isolation valve on the right between the pump and filter and the main water supply in blue:
But if that checkvalve fails and the isolation valve is open, the tank will fill from city water pressure and then it will overflow out. With the vent underneath, it could flood the inside of the trailer. Also, the new water fill is a tight seal, not open like it was originally so it would not flow out there.
An alternative would have been to direct the vent somehow into the sink drain. I did see some plumbing parts at Lowes that might have worked for that, but had already bought the vent fitting and installed it. But with the way it is set up now, if it does backfill then there is a easily seen flow, otherwise it could leak back into the drain and you would never know it. HTH.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 05-07-2014, 10:33 PM   #16
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Thanks, Bob. It is the overflow issue that I did not understand. Hank
See my 1956 Flying Cloud renovation thread.
RankAm is offline   Reply With Quote
Old 07-27-2015, 03:31 AM   #17
flaagan's Avatar
1972 29' Ambassador
Cupertino , California
Thanks for posting this up (with pics, no less)! I'm just getting to figuring out what I was going to do with the fill port on the Ambassador I'm fixing up. The key slot's been damaged beyond repair, and the tab it locks against has been bent back slightly so the door doesn't stay closed. This marine setup (and the vent cap as well) is exactly the solution I was looking for.
MogRod: a '66 Morgan +4 resto-mod project
2014 Corvette Z51 Stingray: the daily driver
1972 Airstream Ambassador: the new toy / project!
flaagan is offline   Reply With Quote
Old 07-27-2015, 10:26 AM   #18
aquinob's Avatar
You're welcome. Post some pix when you are done.
Old 07-27-2015, 10:46 AM   #19
2010 25' FB Flying Cloud
Davenport , Iowa
another mod I would like to see done is replacing the fresh water dump valve with a blade type valve like on the black and grey tank. This would allow for better flush and cleaning of the fresh tank. A SOB 5er that I had had one.
mike
Airtandem is online now   Reply With Quote
Old 07-27-2015, 11:45 AM   #20
flaagan's Avatar
1972 29' Ambassador
mike
Since redoing / repairing the kitching plumbing is part of what I'm working on next, got an example of the kind of valve your talking about?
Old 07-27-2015, 11:46 AM   #21
flaagan's Avatar
1972 29' Ambassador
I will try to remember to do that, I'm way behind on posting photos in my own project thread.
Old 08-02-2015, 12:33 AM   #22
flaagan's Avatar
1972 29' Ambassador
Heya Bob, got it set up, and here's some pics. Thanks again for sharing this info with us!
http://www.airforums.com/forums/f354...ml#post1662321
Old 08-02-2015, 06:30 AM   #23
aquinob's Avatar
Beautiful work. The original water fill is just a poor design overall and if you depend on that water for drinking, it should be replaced and the tank dropped and cleaned.
Old 08-02-2015, 09:12 AM   #24
albert's Avatar
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Tulum , Mexico
Send a message via AIM to albert Send a message via Yahoo to albert
Great info, pics and help. I will be coming back to this thread many times! Thank you all!
albert is offline   Reply With Quote
Old 08-02-2015, 01:22 PM   #25
flaagan's Avatar
1972 29' Ambassador
No kidding. "Lucky me" mine was damaged by the previous owners!
Old 08-09-2015, 06:41 PM   #26
albert's Avatar
1970 29' Ambassador
1957 26' Overlander
Tulum , Mexico
Valve system
I would love to learn more about your valve system. I am gutting a new purchase of a 59 flying cloud and will be doing everything new. I like what you have done, if you would mind explaining it in simple speak, I would really really appreciate it! Perhaps via PM.
Thanks!
Hank
Old 08-11-2015, 01:10 PM   #27
aquinob's Avatar
Albert
The cold and hot (blue and red) come from the back of the trailer. The picture shows incomplete plumbing, there are now two lines going up to the sink hot and cold faucet. There are also two valves that allow for draining each line down through the floor to winterize. When they are closed, pressure is maintained to the kitchen faucet.
If you look, there is one line that is the translucent tubing with the white cross hatching. That is the output of the water pump and it is cross connected back into the cold water supply. The idea is that if you are on city or park water, you close that valve and the water then can only go up to the sink. If you are running on the pump, you open that valve and then the cold water can go back to the sink as well as flow back aft to the rest of the system including the hot water heater.
The valve also serves another purpose, it isolates the pump and tank so that when you are on city water, the tank does not backfill, even if there is a check valve in place. As far as I know, this was the original setup with the copper plumbing as well. It may not look like it, it was much more of a mess when I first started working on it and it took some head scratching to figure out how they had it all connected.
Hope this helps, feel free to ask any more questions.
Noobie - how to fill fresh water tank? Bohemian Fresh Water Systems 26 10-18-2016 01:51 PM
[B]Marine Grade and Pressure Treated Plywood[/B] JimCat2000 Repairing/Replacing Floor &/or Frame 5 03-27-2014 04:18 PM
replacing 12v fixture with LED fixture funkill Lights - Interior & Exterior 2 08-26-2009 10:20 AM
Fresh water tank fill jfowler218 Fresh Water Systems 4 04-21-2009 07:36 PM
Fresh water fill Safari Tim Fresh Water Systems 6 05-20-2007 03:50 PM
