Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 06-29-2002, 04:15 PM   #1
GTracer
GTracer's Avatar
Profile:
Images: 16
Replacing plumbing lines
I've actually started to take out the cabinets to epose all the plumbing. If you were going to replace all the lines what would be the best type of line to use. I was told by someone I should home depot-ize the whole system so it will be easier to work on. And I'm talking about putting in CPVC with regular home fixtures.........Is this a bad idea??????
GTracer is offline   Reply With Quote
Old 06-29-2002, 11:02 PM   #2
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Here are a couple of AirstreamForum links for you. They have links in the posts to several other sites with the materials that are used in current trailer construction.
http://www.airforums.com/forum...&highlight=PEX
PEX tubing with brass, copper or plastic fittings are the current materials used. Copper was used for years and still can be used if you know what you are doing, but will not take a freeze very well and has been mostly replaced with PEX.
Although PVC or CPVC is incredibly easy to use and very inexpensive, it should not be used in a travel trailer or RVMH due to the flex and movement. Also, it is a brittle piping that will break easily if something should strike it. It is meant to be protected in stud walls, attics or buried in the ground.
Fortunately, trailers use standard residential plumbing fixtures on 4 inch centers. You can spend as little or as much as you want to. No need to go to an RV store for any of these. Hit the Lowes, Home Depot or other DIY stores. Moen was and is still used today. American Standard, Price Pfister, Delta and too many more to list, all make quality products.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
plumbing pics for 77 Sovereign? maznblu Plumbing - Systems & Fixtures 3 04-14-2004 07:27 PM
Holding tank plumbing question yukionna 1999 - 2004 Bambi 15 09-10-2003 08:00 PM
Plumbing - A Mystery Pipe Tamara Plumbing - Systems & Fixtures 8 04-18-2003 12:56 PM
Replace copper water lines in 61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
