Old 10-22-2014, 03:04 PM   #1
1973 Argosy 22
1976 Argosy 24
Cutchogue , New York
Replacing plumbing
My 1973 Argosy has copper plumbing. It's a mess of old repairs using rubber hose with clamps, and PVC. Should I repair everything with copper, or pull it all and use polyethylene pipe?
Sdbraverman is offline   Reply With Quote
Old 10-22-2014, 03:22 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Neither. Take it all out and replace with PEX. A really nice plumbing system for a trailer.
Bill M. is online now   Reply With Quote
Old 10-22-2014, 03:23 PM   #3
1973 Argosy 22
1976 Argosy 24
Pex is what I meant by polyethylene.
Old 10-22-2014, 03:35 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Pull it out and replace with PEX style tubing and fittings. It's time consuming, but will eliminate your plumbing leaks for a long time to come. I consider it a significant improvement to my old Trade Wind. I'll be sure to boast about it in an ad to sell when that day comes.
David
Name:	1404 Plumbing Bypass Valves 1.jpg
dbj216 is online now   Reply With Quote
Old 10-22-2014, 03:39 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
A pex conversion on these old trailers is pretty easy.
The work I did on my 75 took a day or two including taking apart and putting together for access. Click image for larger version
Name:	ImageUploadedByAirstream Forums1414013952.330101.jpg
ID:	224931Click image for larger version
Name:	ImageUploadedByAirstream Forums1414013990.864931.jpg
Old 10-22-2014, 03:39 PM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
PEX is what Airstream uses in all their modern trailers. Much lighter and more forgiving than copper.
Bob Martel
WBCCI# 5766
Old 10-28-2014, 07:42 AM   #7
1973 Argosy 22
1976 Argosy 24
There seems to be a difference in the pex pipe and fittings used in RVs and that used in houses.The household stuff sold at Home Depot is a lot cheaper. Any reason not to use it?
Old 10-28-2014, 07:45 AM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
No reason at all.
I replaced ALL of the copper in my ARGOSY with PEX. 23,000 miles; 5 years and ZERO problems. Bought it a Menards.
Old 10-28-2014, 08:20 AM   #9
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
PEX is definitely the way to go. We did it 5 years ago and have had absolutely no problems.
Caution: Draw a complete diagram of the old system before you tear out the copper.
Old 10-28-2014, 09:20 AM   #10
2012 30' Flying Cloud
Lake St Louis , Missouri
X2 for making a diagram. A must for me whether it's plumbing or electrical.
Barry
WBCCI 11988
AirEgger is offline   Reply With Quote
All new Pex - replacing old plumbing GAT Fresh Water Systems 30 01-29-2011 03:38 PM
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
Replacing plumbing lines GTracer Fresh Water Systems 1 06-29-2002 11:02 PM
plumbing diagram for rear bath maznblu Fresh Water Systems 1 06-18-2002 09:00 AM
getting to plumbing maznblu Fresh Water Systems 4 06-05-2002 07:21 PM
