Old 10-15-2015, 05:05 PM   #1
1975 25' Tradewind
Scottsdale , Arizona
Replacing Fresh Water Tank
1975 Land Yacht...a "critter" has chewed a hole in the fresh water tank. I can't see any way of accessing the tank to replace it without ripping out the flooring. Has anyone else ever replaced a tank? There has to be an easier way.
Dixie75 is offline   Reply With Quote
Old 10-15-2015, 05:38 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
You should be able to get the tank from the bottom, one way or the other.
Brevi tempore!
Old 10-16-2015, 04:43 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
The same tank was used on 1972 through 1977 according to the Inland RV web site: Inland RV Center Inc.
You cannot remove it from above as there's a framing cross member that spans the center of the tank.
To access it, there's a 1 1/8" thick plywood bottom that slides out toward the front under the trailer. To get the plywood out, you need to remove the Z shaped angle iron that holds the front of the plywood in place. Then, you simply slide the plywood out toward the front of the trailer, and catch the water tank as it falls.
Ok, that is very over-simplified. There are several gotchas in doing this:
1. You probably have to remove the front stabilizer jacks to gain clearance to slide the plywood out.
2. Everything will be rusted in place. Removing the bolts on the front angle iron may be tough.
3. The plywood may have been caulked to seal it in place. If that's the case, you may need to cut the caulking carefully with a putty knife or utility knife.
4. Sliding the plywood out may be a bear. Even if there is no caulk. It has sit inside the angle iron channels for 40 years. Some folks drill a hole in the front of the plywood to attach a rope or come-along to.
5. The plywood supports the water tank. Once you get the plywood about 1/2 way out, you should have clearance to disconnect the water lines and sensors on the side of it. This would be a good time to support the tank as well so it doesn't fall on you while removing the plywood the rest of the way.
6. Lastly, the piece of plywood is heavy. Extra hands to get it out the rest of the way and to re-install it will make it easier.
The tank itself is not heavy, just kinda big. And expensive.
But, having said all that, it's a doable project as long as you're ok with crawling under the trailer.
Look at our Little Girl Refurb thread post #266 for a fairly good picture of the fresh water tank plywood under the trailer. That'll give an idea of what to look for under yours.
http://www.airforums.com/forums/f185...-50967-19.html
Good Luck!
Chris
Old 10-17-2015, 08:11 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There is some more discussion about removing/replacing/repairing the fresh water tank at the following link:
http://www.airforums.com/forums/f443...-a-142261.html
Getting the sheet of plywood that supports the tank to slide is the biggest challenge in the process. A come-along helps!
good luck!
Old 10-17-2015, 08:25 AM   #5
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
I screwed a sheetmetal strap to the bottom of the plywood sheet and used a come along attached to the hitch to pull it out. it was a lot easier than I thought it would be. Putting it back was much worse, but if I had a helper I think it would have been fine.
Can of beans is offline   Reply With Quote
Old 10-17-2015, 11:09 AM   #6
Center Moriches , New York
I'd take it back to the factory in Jackson Center, OH.
NY24 is offline   Reply With Quote
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Fixing or Replacing Fresh Water Tank Utahgoldrup Fresh Water Systems 10 02-17-2014 09:19 PM
Replacing fresh water tank support 15YearsAfter Repairing/Replacing Floor &/or Frame 3 06-23-2010 09:34 AM
Help with replacing pressurized fresh water tank glang58 Fresh Water Systems 14 08-31-2008 08:39 PM
