Old 12-10-2013, 06:46 AM   #15
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Is there an access panel on a 2008 vintage Classic 25fb? My drain valve still turns but its sticky. I'm guessing another year it will have to be replaced. My AS is in storage and its 25F with ice all around so I don't want to crawl under it until a major warm up.
I don't believe there is any access from the wardrobe or under the side couch.
Kelvin
Old 05-04-2014, 01:22 PM   #16
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
I don't want to mess things up further...can someone please tell me how to get this band off. Is the valve glued in place then banded? Pry out with a screwdriver? Any help is much appreciated! Thanks!!!!!
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 05-04-2014, 01:47 PM   #17
enduroryda's Avatar
1994 21' Sovereign
I'm ready to get the dremel out........
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
Old 05-04-2014, 03:18 PM   #18
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Dremel sounds like a fine idea. Mine has normal hose clamps on each end of a short piece of clear reinforced hose ( about 4"). One end of the short hose was the plastic valve and the other was a barb fitting sticking out of the fresh water tank. I had access to both ends and with some difficulty was able to get both clamps off and cut the hose to remove it. Then with new hose simply reversed the procedure. The removable access panel was small and my big hands found it difficult to work but managed to do it. If that's a crimp clamp I see no other choice than cutting it off. Go for it.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-05-2014, 01:44 PM   #19
enduroryda's Avatar
1994 21' Sovereign
Yes it's crimped on. Dremel it is. Thanks for the rubber stamp polarlyse...just needed to get someone's thumbs up on my thoughts. The opening in the access panel also has the same solid crimped on band...and a glued adhesive going from the FW Tank. No room to play with unfortunately.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
Old 10-05-2014, 09:37 AM   #20
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Kelvin
My fresh water tank is enclosed in a rotocast resin shell. No access panel. I'm hoping I can just unscrew the valve and pull it out enough. I've sent this question to Airstream.
Kelvin
Old 10-05-2014, 10:48 AM   #21
retired USA/USAF
2001 30' Excella
Don't count on it being THAT easy. Mine had an access panel and it was still a PITA to replace.
Roger in NJ
TAC - NJ 18
Old 10-18-2014, 07:25 PM   #22
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Airstream said to cut the rotacast shell, then fabricate an aluminum plate. Dumb design.They could've easily designed the rotacast shell with a hatch. Maybe I'll never have to replace it. Yeah, right.
Kelvin
Old 11-15-2014, 11:49 AM   #23
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Freshwater drain replacement
How much clearance is there between shell and the tank? My luck I would cut into the tank. Thanks
grizbear is offline   Reply With Quote
Old 02-15-2019, 06:41 PM   #24
2017 27' Flying Cloud
Fort Worth , Texas
I know I am replying to an old thread, but the topic is relevant.
I am trying to replace my fresh water drain on my Flying Cloud 27' FB. There is an access panel that I have removed from below the drain. However, as you can see in the picture, the access panel is covered with a piece of styrofoam. I have no idea what the purpose is for this styrofoam, but I am reluctant to remove it since I don't know the consequences. For those of you who have replaced the drain, did you run into the same situation?
Thanks!
billrector is offline   Reply With Quote
Old 02-15-2019, 07:14 PM   #25
DaveP's Avatar
2004 28' Classic
Monument , Colorado
This is how I resolved my fresh water drain problems. And, it drains the whole tank in about 15 minutes...
http://www.airforums.com/forums/f458...ml#post2167935
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 02-15-2019, 08:12 PM   #26
Fort Worth , Texas
Nice, but how did you access the area behind the valve to remove the plastic tube and hose clamps?
Old 02-16-2019, 05:24 AM   #27
Long Island , New York
Thanks!
If you push up on the foam, or try to slide it around, do you feel any "play" in the foam? Can you get it to move a bit? My guess is that it is just insulation and that you could cut it out and replace it with something.
If, however, it feels like the tank's weight is resting on it, back to the drawing board. Personally I would be inclined to cut a hole in the foam so that you can see behind [above] it. You can always use spray foam to plug the hole.
Good luck,
Peter
OTRA15 is online now   Reply With Quote
Old 02-16-2019, 05:29 AM   #28
Fort Worth , Texas
Good luck,
Peter
I too think it is just insulation. My guess is that it feels only 1/2 thick but it is significantly bigger than the access hole. If I push up on it, it goes a short distance and will then move the drain slightly.
