Old 02-25-2009, 07:14 PM   #1
HeadnOut's Avatar
Ruther Glen , Virginia
replacing fresh water drain valve
I have a new fresh water drain valve for a 05 25' safari. Was told to take the 2 scews out and pull out on valve and disconnect the hose and reconnect it to the new valve and reinstall screws..........so easy.........
Well Ive got the screws out and the valve will spin all the way around but it will not pull out so that I can disconnect from hose......
Any help is greatly appreciated
Dave
HeadnOut is offline   Reply With Quote
Old 02-28-2009, 02:15 PM   #2
wppii's Avatar
2004 28' International CCD
East Nicolaus , California
Images: 33
ditto
Sorry, I'm not going to be any help.
I just came down with the exact same problem with a 28' CCD. I just want to get it off so I can reseal the valve to the tank.
Was hoping to find direction here, at least I found out that there is a hose connected to it. I'll keep you posted with what else I find.
The Lovin' Oven is an 04 28' International CCD.
It follows where the F150 Supercrew leads.
"The only time to say "No" is when they ask if you've had enough"
wppii is offline   Reply With Quote
Old 02-28-2009, 02:21 PM   #3
wppii's Avatar
Images: 33
try this thread
http://www.airforums.com/forums/f443...pair-5206.html
Old 02-28-2009, 02:36 PM   #4
HeadnOut's Avatar
update on the fresh water valve replacement....after getting the old one off...or i should say braking it off...I found that the hose clamp that holds the fresh water valve and the hose is behind the tank cover...so instead of dropping the whole tank cover everytime I have a problem with this valve, I just drilled out the hole a little bigger so that the hose with clamp now just slides out of the now larger hole...one issue i found is that the length of hose barely extends past the cover...makes for a tight fit, but all is working properly again.
Old 02-28-2009, 08:10 PM   #5
wppii's Avatar
Images: 33
OK, so it is mounted to a tank cover. That answers one question. It means I have a leak into the space between the cover and the tank because my valve leaks around the flange, not out the spigot.
Thanks so much for the reply, it has helped immensely. I hope to be able to repay someday.
Thanks again, Bill
Old 05-13-2009, 10:19 PM   #6
2005 28' Safari
dallas , Texas
i drilled the hole a little bigger, but it feels like the hose is too short...how big a hole did you drill?
duster767 is offline   Reply With Quote
drain valve on fresh water tank: '79 Argosy 6.0 campman All Argosy Trailers 7 01-26-2009 06:59 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
Fresh water drain valve nilesrob Fresh Water Systems 3 11-10-2006 08:23 PM
Fresh water drain ? TexasStars Fresh Water Systems 6 10-29-2003 12:09 PM
Fresh water drain Happycampers Fresh Water Systems 0 07-21-2003 04:54 PM
