Old 07-25-2008, 08:21 PM   #1
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
replacing copper water lines
Is it worth the effort to replace the existing copper water lines in my 68 ambassador with plastic?
The trailer water lines don't leak and work fine. It would be easy to get to them as they run through the inside of the trailer.
just not sure if the new plastic lines are better or not...
I know they flex if they start to freeze, but i would think they would retain chemical taste more than copper?
Old 07-25-2008, 08:25 PM   #2
Images: 59
I wouldn't replace them just for the heck of it. If you are conscientious about draining the lines before they freeze, then it's not worth the effort.
But they only have to freeze once to make it worthwhile.
There isn't any chemical taste if you use Pex.
Old 07-25-2008, 08:34 PM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
If it ain`t broke ,don`t fix it.Just winterize it good.
easyride is offline   Reply With Quote
Old 07-25-2008, 08:34 PM   #4
Darol Ingalls's Avatar
If it aint broke, don't fix it! Be sure to drain the copper completely to prevent freeze damage and they will last a long time yet. Removing the copper and replacing with PEX is (1)NOT EASY, (2) sort of expensive. Not something you want to do just for fun. Go camping instead. Darol
Darol Ingalls is offline   Reply With Quote
Old 07-25-2008, 08:39 PM   #5
purman's Avatar
1968 28' Ambassador
thanks, I think i will spend the time camping...
Old 07-25-2008, 09:42 PM   #6
63Silver's Avatar
1963 28' Ambassador
Smiths Grove , Kentucky
Images: 43
We just finished replacing our copper lines (po let them freeze in SEVERAL places). While not the worst job, I would not do it again unless I have to. We had trouble finding fittings for the faucets. PEC's is really expensive when you calculate the number of fittings you will need. Best of luck!!
63silver
63Silver is offline   Reply With Quote
Old 07-26-2008, 10:25 AM   #7
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Pretty much the same here: We're replacing the copper with pex piecemeal as we get failures or repairs to do on the old. The hardest part is to locate splice material to connect the pex to the copper.
Lynn
WBCCI 21043
Replacing Water lines in 31' 76 Sovereign 76sovereign Fresh Water Systems 8 02-07-2008 11:47 AM
REplacing Copper in tub/shower HELP!! Sunny51 Plumbing - Systems & Fixtures 0 07-16-2007 08:45 AM
Adding a barbeque addapter to existing copper lines letsgo LP Gas, Piping, Tanks & Regulators 3 10-12-2005 10:02 PM
replace old copper water lines with plastic pipes m. Clarke All Argosy Trailers 7 03-26-2004 11:42 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
