Old 01-19-2015, 08:07 PM   #1
oldtrucksrul's Avatar
2009 27' FB Classic
Southlake , Texas
Replacement pump for Shurflo Smart Sensor 4900-0211
I have a 2009 Classic with a Shurflo Smart Sensor 4900-0211. (I don't believe it's the original pump.) It sprung a leak on this last trip and needs to be replaced. I've repaired it once before. So, what should I replace this model with? I believe it has been discontinued.
Thanks!!
oldtrucksrul is offline   Reply With Quote
Old 01-19-2015, 08:24 PM   #2
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I believe the replacement pump is the 4048-153-E75. Shurflo Revolution RV 12V Water Pump 4GPM High Flow - $139.90
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 01-19-2015, 08:42 PM   #3
1974 Argosy 20
Kooskia , Idaho
I have used both Shurflo and Flojet pumps and find both to be good. Flojet is generally a bit cheaper. I have the variable speed smart sensor type in my FC 20' and honestly don't find it a bit better than the old constant speed pump in my '74 Argosy. If I was replacing the new variable speed today I probably would use an older type constant speed pump and save the money. That is my opinion only of course.
Old 01-19-2015, 10:38 PM   #4
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
I've had luck replacing the rubber diaphragm in my pump, with a piece of rubber roof material. I suspect tire inner tube would be about the same thickness. Lasted from '07 to last summer, when I changed it out again in an hour. Use a .22 brass and small hammer to make the screw holes, a .30 or .38 brass for the other holes. I'd make an "accumulator" by inserting a vertical piece of pipe somewhere in the system where you could adjust the amount of air in it. Probably about the same as putting in a piece of vertical pipe in the house to stop water hammer. The air helps moderate the water hammer pounding.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-20-2015, 05:24 AM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Flexible steel braided water lines from the pump to the initial PEX connections also work very well.
Old 01-20-2015, 12:18 PM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Talking
My smart sensor was replaced under warranty with a shurflo with a4048-153- E76.It seems to be a better pump. The smart sensor pump was obsoleted by shurflo , so they must had problems with them..
Old 01-20-2015, 03:03 PM   #7
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Installed the Shurflo Revolution 2 years ago its much quieter more pressure and no more knocking when running.Cheap upgrade and a great pump.
Old 01-20-2015, 06:48 PM   #8
2009 27' FB Classic
Southlake , Texas
Thanks for all of the info. I'm most likely going to try the 4048
Thanks!
Leaky SHURflo Pressure Sensor Freeheel Water Heaters, Filters & Pumps 4 07-03-2013 03:54 PM
New Shurflo pump quit working? Lothlorian Water Heaters, Filters & Pumps 9 12-14-2008 06:08 AM
shurflo water pump, which one? urbanfood Fresh Water Systems 24 08-19-2007 04:37 PM
Shurflo water pump urbanextreme Water Heaters, Filters & Pumps 13 05-18-2006 10:18 AM
Shurflo pump problems toastie Water Heaters, Filters & Pumps 14 05-17-2006 08:32 PM
