Old 08-15-2007, 05:19 PM   #1
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
Replacement Pump for pressurized water tank
I am looking for a replacement air pump to pressurize a mid 50s or like fresh water tank. Anyone know where I can find one?
Doug
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 08-15-2007, 06:05 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Water Pumps
Hi Doug,
Use the “Search” link on the blue bar above. There are several threads about water pumps. For example:
http://www.airforums.com/forums/f445...tor-35062.html
http://www.airforums.com/forums/f443...one-34281.html
http://www.airforums.com/forums/f443...tor-32191.html
Vaughan
Old 08-15-2007, 06:26 PM   #3
dudebb's Avatar
1962 16' Bambi
Newtown Square , Pennsylvania
Hi Doug,
I just got off of eBay and there is a 60's water pump up for auction. Check it out as it may be similar to what you need. Don't know if it pumps water or air.
George
1962 16' Bambi (sold )
1996 Buick Roadmaster Estate Wagon
Airforums# 7906, WBCCI #4248, WDCU
dudebb is offline   Reply With Quote
Old 08-15-2007, 06:31 PM   #4
1956 22' Caravanner
hmmm
THanks both. What I'm looking for is a new compressor which I can pump up a stainless steal water tank, like the one I had in my 56' caravanner. I have the old pump but it does not work.
I was thinking of an airpump with a regulator to keep it at 40-50psi and then a pressure switch to stop the pump, but I would not mind finding one complete unit.
Any ideas?
Doug
Old 08-15-2007, 07:02 PM   #5
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Doug
I don't have any ideas where you can get an air pump for that purpose, but I would like to relay what I just experienced at work. We have a 5000 gal. water tank filled from a well, there was and air pump to keep a cushion in the top of the tank. The air pump failed and we had someone hook up a regular air compressor to the tank. Needles to say it spit oil into the tank now all of our drinking water is contaminated. They will have to drain and clean the tank to get rid of the oil.
I guess the moral is, get an air pump made for this purpose.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 08-15-2007, 08:04 PM   #6
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
In the parts classified section here, someone is selling an old pressurized tank, maybe you could check to see if they have the pump.
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 08-15-2007, 09:11 PM   #7
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I have a similar air pump in my 1961 Safari. Grover Products air compressor #1393. I took it apart, cleaned it up and refilled with the proper oil, thanks to the helpful folks on this forum. It now works great. I like the air pressure system because I don't have to listen to the water pump every time I run some water. Grover Products is still in business and I believe still sells a similar, if not identical, pump with automatic pressure switch. Look up Grover Products on the web. The last address I have for them is: 1233 South Hope Street, Los Angelos, CA. Use the search link in this forum for "Grover air compressor oil". I seem to remember more good information in that thread.
Good Luck!
Sam
samb is offline   Reply With Quote
Old 08-16-2007, 03:18 AM   #8
Images: 59
You can buy any air compressor used for air horns. Here is a link to a source on Long Island. Add a cut off switch from a well pump and you're good to go.
I have an original but it would be cheaper to buy new.
Also, add a pressure relief valve for safety. The original set up didn't have one. Bad on Airstream.
Old 08-16-2007, 04:27 AM   #9
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Doug-
I have the original pump from our 1960 nTrade Wind that I have not yet posted in the classifieds section if you are interested.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 08-16-2007, 09:24 AM   #10
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Ask and you shall receive.....
eBay Motors: AIRSTREAM PRESSURIZING AIR PUMP FOR WATER TANK (item 280143321981 end time Aug-21-07 11:58:45 PDT)
Old 08-17-2007, 08:42 AM   #11
1956 22' Caravanner
Great info
I would like to buy a new pump rather than adding in an older version only because I have not had great luck with rebuilt or used products in the past. Could be said about new ones as well
Anyways, I found an air pump from viair with a 2 gal tank for $199, but the prior post concerned me about oil in the water. So I would have to include a filter and regulator.
Having a compressor onboard would be very handy for odds-n-ends, maybe the odd air tool such as an impact wrench.
Doug
Old 09-04-2007, 11:44 PM   #12
1960 24' Tradewind
santa barbara , California
Hello there muddy hollow ,Im kinda late on this subject now ,but I too use the original grover pump ,and it does in fact work very well .They are pretty basic and do have a shutoff pressure switch on them .The Grover of today looks exactly like the old red unit (most were red ) but I think its like 400 bucks .Im
looking into these aftermarket air compressors for air suspensions or air bags
they don't have oil in them that could get into the bag or your tank .Oil in
the rubber airbags would destroy the rubber .So check the car magazines
or online source under air bag suspension compressors .you would have to get a pressure switch to shut it down .Ive plumbed in an air pressure gauge that sits below the wall switch in my 60 tradewind so I can always note the pressue and monitor it when it pumps up .Oh,and these air compressors are designed to pressurize air tanks .
good luck
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 09-16-2007, 06:18 PM   #13
1960 24' Tradewind
A follow up to my above post for any interested folks .I have found a vintage Coleman air pressure pump that I installed today on my trdwnd .It works absolutly fantastic ,great ,fast pressure quickly .this coleman is basically the same design as the grover ,has the 50 psi pressure switch on it and only required a brass union to connect it to the air line, slightly different than the grover .So other possible air pressure pumps can be found made for older air pressure systems ,this vintage coleman certainly was a great find .
Old 09-16-2007, 11:21 PM   #14
1960 24' Tradewind
Oh I realize i forgot to mention that my Grover started to fade badly on my recent outing and required extensive running to get decent pressure ,I had
went thru it ,lubrication and so on years ago ,so thats the reason for the coleman ,no need to change the system ,just easier to get another pump .
Scott
Water pump recycling update.... Guitars Water Heaters, Filters & Pumps 6 11-27-2002 07:33 AM
Water Pump Craig Water Heaters, Filters & Pumps 7 10-18-2002 09:26 AM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
