Old 06-01-2010, 12:25 PM   #1
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
Question Replaced city water SHURflo pressure relief valve fitting
Ours was leaking after (only?) 4 years. I found the metal version for 65 PSI is a standard SHURflo RV part so we put a new one on this morning. The original had plumbers putty around the inside plus what looks like silver silicone around the outer edge. Easy enough to find the plumbers putty but does anyone now what I should use around the outer edge where the fitting meets the trailer skin? I'd like to use the same silver stuff. I guess I could use regular clear silicone too. I want to make sure water doesn't get in between the walls (again) from the outside elements. Like me washing the trailer.
Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 06-01-2010, 12:57 PM   #2
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Also known as Vulkem, but the link is here.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 06-01-2010, 01:00 PM   #3
2008 27' Safari FB SE
Mesquite , Texas
Hi Ken -
Silicone and aluminum don't mix. It will never stick well enough to keep the water out. I would guess it is either Acryl-R or Sika Flex. Sika Flex is a caulk that you can get in a lot of places. The gray color is what Airstream uses. Acryl-R is meant to fill much smaller gaps. It is what A/S uses typically as a seam sealer. The bead can be very small. The only place I know to get it is either from an A/S dealer or from the A/S store. It is in the maintenance product section.
Hope that helps.
wayner61 is offline   Reply With Quote
Old 06-01-2010, 01:32 PM   #4
silverback's Avatar
2006 28' Safari SE
Thanks guys. I will get some.
-Ken
4CU Charter Member
Water heater pressure relief valve woliners Water Heaters, Filters & Pumps 6 07-10-2008 07:12 AM
pressure relief valve twiggy137 Plumbing - Systems & Fixtures 10 05-13-2008 08:20 AM
Pressure relief valve CBsquidSS Fresh Water Systems 4 03-03-2008 02:43 PM
water heater pressure relief valve wayne.yl Water Heaters, Filters & Pumps 12 04-21-2007 05:54 AM
Bowen Pressure relief valve melprice Water Heaters, Filters & Pumps 5 06-16-2002 06:47 AM
