Old 04-01-2013, 10:37 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Replace Pressure Relief Valve
My pressure relief valve was leaking (again). This time I am pretty sure the pressure was not too high and it should not have leaked. Can I use a generic replacement or where can I get the part?
Marshall
Old 04-01-2013, 10:42 AM   #2
Marshall
Parts stocking dealers have that pop off valve.
Old 04-01-2013, 11:07 AM   #3
Kevin245's Avatar
I purchased our T&P valve at www.mcmastercarr.com.
Eleanor Roosevelt
Old 04-01-2013, 11:10 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Try this first
http://wbcci.org/general-information...-february-2013
doug k
Old 04-01-2013, 11:17 AM   #5
Kevin.
I did not find any high pressure water pop off valve at McMaster.
Do you have a part number?
Old 04-01-2013, 12:25 PM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
Originally Posted by dkottum View Post
In case I was not clear. The pressure relief valve I need to replace is the in line valve not the hot water heater pressure valve in the above link.
I did see a plethora of valves in the McMaster site, which valves will work for an Airstream application?
Old 04-01-2013, 02:53 PM   #7
Images: 59
The McMaster 4612K16 will work. They're cheaper at Grainger. Also most plumbing supply houses.
Old 04-02-2013, 04:31 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
The description says this is an adjustable pressure relief valve. What would be an appropriate release pressure to set it at?
Old 04-02-2013, 05:06 PM   #9
Images: 59
I would start at 75 lbs. Make sure you plumb the exhaust to an outside location. Keep the extra springs in case you need to go higher.
Old 04-10-2013, 09:01 AM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
When I spoke to RV Supply and Plumbing Supply Outlets first I had to repeat myself 3 times I was not talking about a relief valve for the hot water heater. Then I got a response like I was speaking ancient Aramaic.
Are these type of pressure relief valves no longer used in RVs? Was Airstream the only manufacturer to ever use them?
Anyway Home Depot had the almost the same valve for $16.
Old 02-19-2014, 10:23 AM   #11
1975 25' Tradewind
VA Beach , Virginia
Not real sure of the "Necessity" of pressure relief valve, if water heater has one and "City water" has Regulator that valve is redundant
jimrich60 is offline   Reply With Quote
Old 02-19-2014, 10:36 AM   #12
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Actually, that's not necessarily true. A pressure regulator guards against overpressure from municipal water. What guards against overpressure from your pump (i.e. pump doesn't shut off when it's supposed to)? A pop-off valve or pressure relief valve. Depends on just where in the system your pressure relief valve would be installed. If it's at the municipal water inlet, then yes, it's redundant. If it's downstream of the pump, it's not.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
