Old 08-15-2016, 11:30 PM   #1
2008 19' Bambi
Largo , Florida
Replace or repair water pump
I just got my home after 8 months in storage.
I'm now fixing a few things on it to get it ready for my first trip and I discovered that the water pump isn't working to my dismay.
Before I moved it, the pump seemed to work fine, but when I tried it now, it wouldn't come on at all.
I was looking in the compartment and touched a wire and suddenly it started to run. If I jiggled the wires I managed to get it to run and stay on. It built up pressure, but then suddenly it started to have a burning smell.
I shut it off and left it at that.
My Airstream is a 1976 Overlander.
Should I replace the pump and have a safer system? What specifications do I need (3 GPM? 55 PSI?)
What brands do people use and are you satisfied with them today?
Elijah
eliyahu is offline   Reply With Quote
Old 08-16-2016, 01:54 AM   #2
1988 Argosy 32
Lomita , California
If it smells burnt it is prob toast, the new pumps run way quiet with a strong flow, shop around.
Wolfe is offline   Reply With Quote
Old 08-16-2016, 02:24 AM   #3
2008 19' Bambi
Largo , Florida
whats the recommended flow I should have 3 or 4 gallons per minute?
Also: it's a 76 overlander: I can see the pump through the small opening just next to the door, but is that the way to access it? It's so small! How do I access the pump to change it?
Eli
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
How do I replace the water pump in 2004 Land Yacht? cfanna Land Yacht/Legacy Motorhomes 8 05-20-2015 09:07 AM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Anyone replace OEM aquatic II water pump with Sureflo Revolution? bonginator Water Heaters, Filters & Pumps 1 08-01-2014 09:06 AM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
