Old 05-21-2002, 10:46 PM   #1
Replace copper water lines in '61 Bambi
Now that I have stripped the interior out of my unit, I have noticed that the copper plumbing is green and rotten is some spots and have decided to replace it all. Has anyone ever replaced the copper with the newer stylr plastic or PVC lines you see in the new trailers? Does anyone know how to remove the black water tank and the shower stall? it seems that there are three old lines running behind there (someone cut them off and bypassed the the tank/shower by running the lines in front (exposed) of the shower sill). Its obvious that the cold line runs behind there to service the kitchen sink and the hot water tank. The second line runs in the opposite direction carrying hot water to the shower. Any ideas why the third line?
61BambiCanada is offline   Reply With Quote
Old 05-22-2002, 06:04 AM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
If you have removed all of the cabinets, removing the shower surround itself is pretty easy. It is getting it disconnected that is the hard part. You will just have to drill out all the rivets, disconnect the supply water lines, remove the toilet and disconnect the shower P-trap and waste tank drain lines. Use care disconnecting the dump valve from the waste tank as these are expensive and hard to find. To remove the waste tank, cut the vent line that goes to the roof and unscrew the toilet flange from the surround. You will have to fabricate a tool to unscrew the flange seat that attaches to the waste tank. Repair the vent line with a rubber drain line pipe clamp that has 2 worm clamps. Also check the vent at the roof as with all this movement you will have just created a big old water leak on the roof.
The other part will be getting the belly pan off to get to the drain lines. (See my post to you on repairing the floor)
Work with care on the fiberglass, as their is no replacement showers available unless you find another old Bambi for parts.
Best Regards
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Hard To Replace Sony In '06 Bambi? jambie Audio, Video & TV 19 08-24-2012 12:18 PM
Easy water removal from lines..worked 4 me Jim & Mitzi Winterizing, Storage, Carports & Covers 6 01-03-2012 06:20 PM
Water in 19' Bambi & Fulltiming zlee Full-Timing 2 11-18-2011 01:13 PM
New black water valve on a 1962 Bambi? amber.indigo Waste Systems, Tanks & Totes 1 09-26-2011 10:28 PM
Need advice on '75 Overlander w/ frozen/burst water lines Denbear Fresh Water Systems 3 03-01-2011 08:47 PM
