Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 05-21-2002, 10:46 PM
61BambiCanada
Profile:
Replace copper water lines in 61 Bambi
Now that I have stripped the interior out of my unit, I have noticed that the copper plumbing is green and rotten is some spots and have decided to replace it all. Has anyone ever replaced the copper with the newer stylr plastic or PVC lines you see in the new trailers? Does anyone know how to remove the black water tank and the shower stall? it seems that there are three old lines running behind there (someone cut them off and bypassed the the tank/shower by running the lines in front (exposed) of the shower sill). Its obvious that the cold line runs behind there to service the kitchen sink and the hot water tank. The second line runs in the opposite direction carrying hot water to the shower. Any ideas why the third line?
Get rid of these ads... register today, it's FREE
Old 05-22-2002, 06:04 AM
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston, Texas
If you have removed all of the cabinets, removing the shower surround itself is pretty easy. It is getting it disconnected that is the hard part. You will just have to drill out all the rivets, disconnect the supply water lines, remove the toilet and disconnect the shower P-trap and waste tank drain lines. Use care disconnecting the dump valve from the waste tank as these are expensive and hard to find. To remove the waste tank, cut the vent line that goes to the roof and unscrew the toilet flange from the surround. You will have to fabricate a tool to unscrew the flange seat that attaches to the waste tank. Repair the vent line with a rubber drain line pipe clamp that has 2 worm clamps. Also check the vent at the roof as with all this movement you will have just created a big old water leak on the roof.
The other part will be getting the belly pan off to get to the drain lines. (See my post to you on repairing the floor)
Work with care on the fiberglass, as their is no replacement showers available unless you find another old Bambi for parts.
Best Regards
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
vB code is On
Pingbacks are On
new water lines Rob Fresh Water Systems 29 07-11-2006 08:25 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
replace old copper water lines with plastic pipes m. Clarke All Argosy Trailers 7 03-26-2004 11:42 PM
Water Heater T&P 99 Bambi Leaking, need advice JimBrownUT Water Heaters, Filters & Pumps 3 01-14-2004 02:46 AM
Water Lines bpaolini Fresh Water Systems 8 09-16-2003 05:43 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
