Old 04-24-2013, 02:43 PM   #1
1989 32' Excella
Anthony , New Mexico
Repairing grey plastic water lines
I am replacing a toilet in a '89 excella 1000 and will have to modify/reroute the water line. Are there any connecting fittings (unions and/or 90 degree) I can use which don't require a crimping tool? The water line is original grey plastic. I have searched the forums to no avail. Also how can I determine the size of the line? Thanks.
bobn51 is offline   Reply With Quote
Old 04-24-2013, 02:55 PM   #2
1981 31' Excella II
New Market , Alabama
There are probably some shark bite type connectors that will work. You can also do this. Dispite what many have said the polybutylene tubing is not that bad but some of the fittings used by Airstream tend to crack. Here is a little history.
http://www.polybutylene.com/poly.html
Fittings:
POLYBUTYLENE repair fittings - PlumbingSupply.com®
Or this
Polybutylene Tube Fittings - Fittings - Grainger Industrial Supply
Perry
Old 04-24-2013, 03:09 PM   #3
247stream's Avatar
1986 25' Sovereign
Cedartown , Georgia
We just repaired our old grey lines by using pex tubing and flaire-it fittings...worked great.
FLAIR-IT by THC
that's their site but we bought our flair-its from our local camper store and no tools are needed to install them, hand-tighten+.
WBCCI# 1558
2016 Ram 1500 Crew Cab 5.7 Hemi
247stream is offline   Reply With Quote
Old 04-24-2013, 03:12 PM   #4
1974 Argosy 20
Kooskia , Idaho
Shark Bite (Home Depot and others) and Tiger Bite (Lowe's) will both work well with gray polly pipe.
