Old 07-06-2019, 09:19 PM   #1
2009 25' FB Classic
Lincoln , Maine
repairing damaged fresh water pan on Classic 25FB
Plumbing, never as easy as it looks! We recently purchased our Classic 25FB in Oregon, and had a driver bring it to our home in Maine. Long the way, the front of the fresh water tank pan was damaged. So I ordered a new one, and am now attempting to replace the damaged cover. Removing the six bolts in front and 6 bolts on the rear was simple, but then.... The whole tank comes down with the pan. I see three pluming connections that must be detached from the pan to remove it. The tank drain line - a short flexible plastic line from the tank to the side of the pan, ending in a white plastic drain valve. The line is attached by hose clamps - loosening these should allow me to remove the line.
But..There are two plastic lines ending in small stopcocks through the bottom of the pan. I believe these are low point drains, connected to plumbing from above.
How does one remove these two lines from the pan? Looking through the access cover opening, I can see large plastic nuts at the inside surface of the pan, but how does one get to these to loosen them, and would this uncouple the lines from the tank?
Any suggestions on how to remove this pan would be most appreciated!
tqflightdoc is offline   Reply With Quote
Old 07-06-2019, 09:46 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Here are some photos that might give you an idea of what’s in there.
Blog post
http://www.airforums.com/forums/blog...lacement-2929/
http://www.airforums.com/forums/blog...t-part-2-2930/
Old 07-07-2019, 08:45 PM   #3
2009 25' FB Classic
Lincoln , Maine
GMFL, thanks for your pictures, and nice work, I might add. So your statement "I had to cut the PEX pipe for the low point drains that was routed through the water tank pan in order to drop the tank. I decided to add a male and female connection to this pipe which would allow me to reconnect the line and disconnect it later if I ever needed to." implies I need to simply cut the two low point drain lines, then reconnect them by installing threaded fittings.
But how to reconnect the fittings with the tank and pan now back in place? Do I now need a larger access opening to allow me to reach the fittings to tighten them? Or is it possible to get an improved stopcock fitting that has a flange on the inside of the pan, and a screw on flange for the outside. With this I could reconnect the drain lines before putting the pan in position, then lift the pan up into position, then tighten the outside flange fittings. Do you think this would work?
Old 07-07-2019, 08:52 PM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I was able to reach mine from inside the trailer. The 23D layout allows you to access the top of the tanks area (where the low point drains and other plumbing goes through the floor) by removing the converter to access the area.
Old 07-08-2019, 08:25 PM   #5
2009 25' FB Classic
Lincoln , Maine
Thanks again. I will see what I can access from above the tank. It will have to wait until this weekend - will report back. I have the trailer up on four good floor jack stands.
There is something satisfying about working on this machine. It has been a good introduction to its inner workings. I live in Maine, and appreciate your insulation work on the water tank. I will do the same.
Old 10-28-2019, 05:49 PM   #6
2009 25' FB Classic
Lincoln , Maine
Back to work on the fresh water pan
Now I am back at work on replacing the fresh water pan on our 25 ft classic.
Questions please:
1. Must the tank come down and be removed while removing the pan?
2. From an access hole in the floor, I can reach the two low point drain lines, but how does one remove the fittings? Or do you simply cut the lines where they come out of the floor and then install shark bite fittings or screw fittings?
3. How does one disconnect the tank to pan drain hose? This is a short length of tubing with small hose clamps on each end. Must the tank and pan come off the trailer together to access and remove this line?
4. If the tank has to come out with the pan, then the water lines to the tank and the pump supply line must re disconnected. Not easy to feel, and unable to see the fittings. Any ideas?
Any suggestions would be greatly appreciated.
Old 10-28-2019, 07:03 PM   #7
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Questions please:
1. Must the tank come down and be removed while removing the pan? Yes, the tank is held in place by the pan.
2. From an access hole in the floor, I can reach the two low point drain lines, but how does one remove the fittings? Or do you simply cut the lines where they come out of the floor and then install shark bite fittings or screw fittings? Correct. You gotta cut the fittings. When I did mine I added back male and female screw fittings.
3. How does one disconnect the tank to pan drain hose? This is a short length of tubing with small hose clamps on each end. Must the tank and pan come off the trailer together to access and remove this line? Yep. You might be able to disconnected it through the access hole in the bottom of the pan, but it will be tight. Best to just drop both at. The same time.
4. If the tank has to come out with the pan, then the water lines to the tank and the pump supply line must re disconnected. Not easy to feel, and unable to see the fittings. Any ideas?Pump line should be able to be disconnected from inside the trailer. The tack fill line will need to be disconnected at the fill spout on the side of the trailer then the hose can be feed through and dropped with the tank.
Call me if you like. I’ve been there 334-332-0003
Old 12-05-2019, 11:40 PM   #8
I have a 2002 25ft Classic. Where did you buy the replacement aluminum freshwater pan? Thanks
umasslax is offline   Reply With Quote
Old 12-09-2019, 10:22 AM   #9
2009 25' FB Classic
Lincoln , Maine
Fresh water belly pan
The fresh water bely pan on my 25FB is made of galvanized sheet metal, and I ordered it through a dealer from Airstream. I have been distracted (updating a hangar) from finishing this job, but will get back to it in January.
Old 12-09-2019, 04:05 PM   #10
Have reached out to several dealers for pricing ... $240 for pan, $30 for tax, plus freight to ship to dealer. This could get expensive. Can't imagine the cost to install on top of that.
Removing fresh water tank -- 2014 25FB part 1 GammaDog Fresh Water Systems 11 10-16-2018 08:48 AM
Fresh Water Tank Pan? SteveandSam Fresh Water Systems 2 01-25-2016 10:34 PM
2008 Airstream Safari SE 25FB trailer camper damaged rebuildable NO Reserve 08 ! eBay Watch Airstreams on eBay 0 07-13-2012 02:50 PM
Fresh Water tank pan? woodfox45 1984 - 1989 Sovereign 3 09-03-2011 11:17 AM
Damaged belly pan sepezlover Belly Pans & Banana Wraps 12 08-19-2011 02:01 PM
