06-24-2014, 11:10 AM
1977 31' Excella 500
Colorado Springs
Repair or replace tank??
I have a 77 excella CB that has a leak in the freshwater tank. How easy is it to repair the tank? What is the cost of a new tank? And finally where can I get the tank? I've looked at airstream parts store and can't find the tank anywhere. It's a large tank with a square cutout in center.
Thanks in advance for answers and help.
Pat
Colorado Springs, Colorado
WBCCI# 9633
AIR# 15430
06-24-2014, 11:15 AM
1978 25' Tradewind
Metro Phoenix
You're probably better off replacing the tank at that age. The next crack won't be far behind. Try Inland RV or Silver Trailer Supply. Note that it might take a road trip to pick up, because the freight on that tank will kick your assets to the curb.
06-24-2014, 06:02 PM
Colorado Springs
Thanks for the info. I will need to check with Inland or Out of Door Mart for the correct tank. My tank is almost square shaped whith a square cut out in the center (Think square doughnut).
Pat
WBCCI# 9633
AIR# 15430
06-24-2014, 06:26 PM
2002 27' Safari
Carmel-by-the-Sea
Interesting. Can you post a photo of your square donut tank? I wonder if yours has been replaced prior.
06-24-2014, 08:17 PM
Colorado Springs
I will post some pics of the tank as soon as I drop the pan.
Pat
WBCCI# 9633
AIR# 15430
06-24-2014, 08:54 PM
2002 27' Safari
Carmel-by-the-Sea
I think this is what you have
Airstream part # 600571
06-24-2014, 09:05 PM
Colorado Springs
Coastalview, that is the tank. Thanks for the post. Any idea of the cost of the tank?
Pat
WBCCI# 9633
AIR# 15430
06-24-2014, 09:18 PM
2002 27' Safari
Carmel-by-the-Sea
07-21-2014, 06:59 PM
1979 23' Safari
Wayland
, New York
One Less probe connection
CoastalView,
I got the same replacement tank, but it only has 4 probe connections vs 5 originally, what did you do to compensate?
Joe
Originally Posted by Coastalview
08-01-2014, 01:20 PM
2002 27' Safari
Carmel-by-the-Sea
Originally Posted by HiJoeSilver
CoastalView,
Joe
Joe, I remember that issue. One probe that isn't in the same vertical alignment is for ground. I ended utilizing the probes for all but the full circuit.
Easily identified when its full while filling.
Hope that helps.
Sold our 78 Ambassador last month
