Old 04-21-2004, 03:32 PM   #1
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Removing Fresh Water Tank
Hello, I need to replace the floor under the fresh water tank in our 1975 Argosy, it is in the front under the gaucho, but I don't have an owners manual. Does anyone know how it is fastened down? I would think it might have bolts through the floor but don't want to take the belly pan down if not needed. Thanks Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 04-21-2004, 03:42 PM   #2
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
The ones I have seen were all taken out from inside the trailer, mine included.
Pull the Gaucho and all will be reveled.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 04-22-2004, 06:35 AM   #3
1979 30' Argosy
Gary, That was the first thing I did, but can't get it to move and don't see any way it is fastened to the floor.
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 05-07-2004, 02:40 PM   #4
markus's Avatar
fresh water tankkkkkkkk
here goes
Upon testing onboard system I seam to have a leak someware!!
After narrowing down the location, there waz no choice but to pull the fresh water tank. onea those-- gotta do it, aint gonna do itself!!
after crawlin under 4 or 5 times I got to it, the tank sits bout 2" lower than the rest of the belly pan forward of the axles. you stand right above it when working the stove.[on a 73 inter 31"]
It is supported by a piece of 1'' plywood witch in turn sits on four 1.5" pieces of steel that I'll call a Z-bar. The forward Z-bar is just bolted on both ends and the others are welded fast to the frame. I cut the bolts off and the bar fell....
the plywood was covered w/aluminum and was sacrificed to the "stream gods"
So not to kill my self I put a 3/8 bolt thru the exposed plywood side and hooked up a comealong to the safety chains of the TT.
the last pic revealing the burst pipe!!
you must remember when pulling plywood out cut two pieces of wood bout 12'
and stick across the two rear corners under tank to hold it up. I also cut a 1x1 57'' to hold up the front of the tank whilst wrestling w/plywood. just for ha haz the plywood weighd 62lbs. tomorrow I fix the pipe.
markus
markus is offline   Reply With Quote
Fresh water tank leak Flex Fresh Water Systems 3 09-30-2004 04:25 AM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 12:37 PM
Problem Filling Fresh Water Tank DaveJ Fresh Water Systems 8 10-14-2003 05:36 PM
Leaky fresh water tank nellie the elephant Fresh Water Systems 3 10-13-2003 02:12 PM
Fresh water tank - slow drip drboyd Fresh Water Systems 5 07-24-2003 07:01 PM
