Old 02-03-2013, 05:08 PM   #1
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
Relocating fresh water tank...
Restoring a 67 Safari... initially, the fresh water tank was under the front window... would relocating it to a position toward the center and possibly BEHIND the axle create a problem with tongue weight?
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 02-03-2013, 06:55 PM   #2
SteveH's Avatar
Common Sense , Texas
In a word, yes. You might get by with moving the tank rearward, but not farther than directly over the axles. You don't want to add weight behind the axles.
Late model Airstreams have the tanks under the floor, between the frame rails, and over the axles, which is actually the optimum place because the water weight does not efect ballance front to rear, but keeps the weight low.
Regards,
Steve
