Old 09-01-2015, 03:42 PM   #1
Fairhope , Alabama
Refit Fresh Water System for 1961 Overlander
I recently purchased a 1961 International Overlander. It currently has the old galvanized (torpedo sized tank) under the twin bed. It is my understanding in order to use the whole water system you need to fill the tank and then pressurize it with an air hose and or use the onboard pump.
Has anyone out there converted this type system to one that can be hooked up to city water and bypass the holding tank?
I would hate to think I had to haul a tank of that size with any amount of water down the road.
I know that the later models had a bypass system that you could fill the tank and use pump, or pressurize the plumbing using city hook up.
I would like to jettison the torpedo tank and replace with a smaller lighter more efficient poly tank and a pump with a pressure switch like the later models. (On demand System)
Any help and suggestion would be greatly appreciated.
Char61Oland is offline   Reply With Quote
Old 09-01-2015, 03:56 PM   #2
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
I think you could add an external city water fitting (threaded hose fitting) to the system, and a valve to isolate the tank, so you can use city water. You'll also need a pressure regulator for the city water, I replaced my plumbed-in-place one with a hose mounted piece. You can replace the tank with a polyethylene one, I replaced my water tank with one from Trionix which I thought was reasonable and quite good quality. I would imagine too that you could just wire in a 12v pump for the new tank, maybe using the wiring from the air pump?
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 09-01-2015, 04:20 PM   #3
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I redid all the plumbing on my trailer and kept the original galvanized tank. My trailer originally had the ability to attach to city water, however the plumbing had been replaced in a very cobbled up fashion. I now have the ability to run off of the tank or city water, as I can completely isolate the tank from the rest of the system through the use of a couple of valves.
I know many here will disagree, but I think the original pressurized system is vastly superior to the modern electric pump systems. Once pressurized, I can run for several days without re-pressurizing. It's silent, and functions exactly like the water in my house. If you have all the faucets closed when you fill the tank, it will automatically pressurize, no need to add air. I've got a 12-volt air pump attached which allows me to re-pressurize with a switch. I also carry a 12-volt air compressor so I can re-pressurize from the truck. If all else fails I could do the same with a hand operated bicycle pump. The only drawback is that it is difficult to monitor the volume of water in the tank. I can get in the ballpark by using an infrared thermometer.
The biggest problem with these is that many of the old tanks are corroded on the inside, and then susceptible to leaking once pressurized. They are difficult to find replacements for. I used a remote inspection camera to see what mine looked like on the inside before I committed to use it.
Thalweg is offline   Reply With Quote
Old 09-14-2015, 12:28 AM   #4
San Diego , California
You may not believe this, but I also have a 61 Overlander, and I am finally getting back to getting some stuff done on it. That torpedo is coming out and something plastic is going in, and I am moving from air pressure to pump on demand.
You can actually (probably) run city water right now - just fill the tank and let the city water continue to pressurize.
photomikey is offline   Reply With Quote
Old 09-15-2015, 06:54 AM   #5
Fairhope , Alabama
I am truly enjoying the Overlander. We went on our second trip this past weekend to the Emerald Coast, (Destin FL).
I have tested the galvanized tank and it appears to be intact with no leaks. I will have to rebuild the spigot on the out side because when I charged the system I could here the air leaking out. I had previously rebuilt the existing toilet and original black water release valve. Everything worked great. The only issue I had was that I did not do anything to the connection from the water supply to the toilet. When I pressurized the system I had a leak around the Febco backflow preventer. I have since pulled it of and rebuilt it as much as possible. Will test the system again this week.
Can anyone that has updated there fresh water to an on demand provide diagram as to there set up. At this point I don't know if I will leave the existing system or convert.
Question: What and where do the three nipples go and do under the tank and water heater. I know one is the tank water release. When I filled and emptied the tank one flowed like a champ but one other just trickled out and the last one nothing came out.
Old 09-16-2015, 08:12 AM   #6
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I had this same problem. I started looking at replacing the valve, but then discovered that it only needed a new o-ring and washer. I'm not used to old-school plumbing. It was a five minute fix after a trip to the hardware store.
Old 05-20-2018, 12:55 PM   #7
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
. . . When I pressurized the system I had a leak around the Febco backflow preventer. I have since pulled it of and rebuilt it as much as possible.
Hi, Not sure of you still monitor the forums, but I have a leaky Febco 710 3/8 backflow preventer/vacuum breaker on my 1962 Airstream. I'd love to know how you got yours apart to rebuild it and what parts you were able to replace.
I can't seem to get mine apart. How did you get yours apart? Heat? Leverage? Penetrating oil?
I assume that If I can get the top off mine, then I may find it just needs a new gasket (which I assume I can make since I doubt I can buy repairs parts for it at this point).
Were there any other parts you replaced?
Thanks in advance.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 05-22-2018, 09:03 AM   #8
Fairhope , Alabama
Fencing 710 3/8
Penetrating oil was my salvation.
I felt torque and or heat and torque would have destroyed it. I looked high and low for replacement to no avail. I am still using old tank. Works well.
Good luck.
Old 05-22-2018, 11:14 PM   #9
1962 22' Safari
2016 30' Classic
Images: 41
Good luck.
Thanks. I got lucky. The Febco eaked when testing the plumbing with air pressure, but it sealed when I later applied water pressure. I think I am good for now, but will use penetrating oil if I have to take it apart in the future.
Joe
WBCCI/VAC #6768
Old 05-24-2018, 07:34 AM   #10
Fairhope , Alabama
Great. I glad it started working. Currently in Bryce Canyon. System under pressure and holding strong.
Is your toilet porcelain? Have you been able to find any of the gaskets to seal to the tank?
1986 Sovereign 31' Refit DanB 1984 - 1989 Sovereign 11 02-03-2013 10:48 AM
1990 36' Airstream Land Yacht w/Tag Axle 2006 Major Refit & Unique Modifications eBay Watch Airstreams on eBay 0 10-13-2011 01:10 PM
Bargman #99 Tailight refit 6-prong to 7-prong silverkeeper 1960 Safari 6 03-05-2011 10:01 AM
62 Safari refit howlentz Member Introductions 1 12-28-2005 07:04 PM
Toilet refit 65 overlander Sinks, Showers & Toilets 2 12-19-2005 11:10 AM
