Old 06-15-2007, 07:47 AM   #15
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
HowieE:
A tank monitor system currently used by Airstream and many MoHo manufacturers.
http://www.catconproducts.com/rv.htm.
Use the search function or look under Plumbing for many references to Micro Pulse.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 06-15-2007, 01:34 PM   #16
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Sergei,
Good job and you will be glad you have the ability to drain the tank when you need to, especially when you haven't used it for awhile and you have to disinfect it. I hate it when STUFF grows in what you thought was an empty tank.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-17-2007, 07:50 AM   #17
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Sergei, I just noticed this weekend that my trailer is plumbed with a drain on the discharge side of the pump. So I am going to close off the tank drain and use the pump to drain the tank. I think I can get more water out of the tank with the pump anyway if I have the trailer on a tilt to the left.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
Sanatizing the Water Tank? 68 Suburban Fresh Water Systems 3 10-13-2002 12:22 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
What Grey Water Tank?? niftypkg Waste Systems, Tanks & Totes 6 09-04-2002 07:12 PM
Holding Tank Wiring 74Tradewind Waste Systems, Tanks & Totes 1 05-23-2002 04:22 PM
