Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 03-04-2007, 07:24 PM   #1
Gen Disarray
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
Re-plumbing 1/2 or 3/8 PEX
OK, one of the items on the spring "dry dock" repair list for the Trade Wind is to gut the fresh water lines and re-plumb with PEX. So here is a list of my current nightmares.
1) Would it be best to use 1/2" or 3/8" tubing? I see several people here who I have high regard for have gone with 1/2". Against that, I have read several comments to the effect that 3/8" tubing will fit the fixtures with less problems, adaptors and what not. Thoughts from those of you who have done this refit would be appreciated.
2) Should I be adding extra cut-off valves or drains in the system? Do the benifits out weigh the leak potential?
3) What do you wish you had thought about before you started that became all to apparent later in the project?
4) Oh yeah, is it pronounced PEX or P-E-X?
Rodney
The trouble ain't that there is too many fools, but that the lightning ain't distributed right.- Mark Twain
Visit my photography page at:http://www.pbase.com/professor_chaos
or my new travel site
Synapticstorms (under construction)
Gen Disarray is offline   Reply With Quote
Old 03-04-2007, 07:34 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
I used 1/2 in throughout, and would do it again. It keeps things simple. All the fittings and pipe are the same.
I went with the flair-it fittings, which worked out great. Their swivel fittings go straight onto the faucet threads, and I had no leaks from the fittings to pex, oly a few drops from the fittings to metal.
I would use more sealing tape next time, to avoid these leaks where the plastic fittings meet metal threads. Other than that, my installation has proven to be reliable and safe.
Uwe
Old 03-04-2007, 07:41 PM   #3
GreatPumpkin
GreatPumpkin's Avatar
Profile:  1964 26' Overlander
Colville , Washington
Images: 66
I also vote for 1/2". I've installed it and had nary a single drop leak. If I was to do it over, I would add elbows, or spring for the tool and do the clamps for better appearance. Mine functions great, but would take up a little less room if I had used some 90 degree elbows.
I used JACO brand slip fittings (I've still got large quantities also if your interested)
JB
AIR 12256
1964 Overlander
1999 Dodge Ram 1500
2001 Honda XR650R
"In regione caecorum rex est luscus."
GP
GreatPumpkin is offline   Reply With Quote
Old 03-04-2007, 08:07 PM   #4
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
My trailer is all 3/8" PEX, done by the PO. Looks great, works fine and no leaks....
Richard
Charter Member Four Corners Unit
Old 03-04-2007, 08:33 PM   #5
kneal
Profile:  1973 23' Safari
Maryville , Tennessee
Images: 13
I am doing mine as we speak in 1/2 PEX with the Quick Connect Fittings that don't require a special tool. They work great and you can get reducers, elbows, T's and interchange with CPVC, PVC, Copper etc...directly between the PEX with these connections.
kneal is offline   Reply With Quote
Old 03-04-2007, 08:52 PM   #6
STREAMTEAM
STREAMTEAM's Avatar
Alamosa , Colorado
Yep, you got it Kneal, I had to re-plumb "Molly" when I brought her back from Ca. to Co. 1/2" PEX and copper matched well, No probs since, of course now I have learned what to do during our sub-zero winters, thanks to many helpful folks on these forums.
Mike
STREAMTEAM is offline   Reply With Quote
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
'63 Safari Plumbing Schematic? petefundis Plumbing - Systems & Fixtures 1 09-18-2002 06:56 PM
Replacing plumbing lines GTracer Fresh Water Systems 1 06-29-2002 11:02 PM
plumbing diagram for rear bath maznblu Fresh Water Systems 1 06-18-2002 09:00 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
