Old 10-22-2013, 06:43 AM   #1
blickcd's Avatar
Milford , Ohio
Rain water gets into fresh water tank
I've noticed that when my trailer is stored for a long period of time with an empty fresh water tank, the level monitor will read 1/4 full. Seems that rain water is getting in through the locked filler door.
This has happened over the winter after the trailer has been winterized and nothing has broken, but this year I would like to take extra precautions.
Is there a gasket that can be made for the filler door, or maybe just put some electrical tape around the edges of the door?
Christopher
Its a camper, therefore it leaks.
blickcd is offline   Reply With Quote
Old 10-22-2013, 07:39 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A better solution might be to add a drip rail over the filler door. Something like this, on a smaller scale…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-22-2013, 02:18 PM   #3
blickcd's Avatar
Milford , Ohio
Nice idea. I think I have some scrap aluminum angle that I can fabricate into a similar shape. I might just "glue" it into place with Parbond or Vulkum.
Christopher
Old 10-22-2013, 05:13 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
In order for rainwater leaking in through that door to show up on your monitor, you would have to be having floods of biblical proportions, like 24"+ per day. Look for another cause.
Old 10-22-2013, 06:06 PM   #5
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Any chance the water heater and lines are draining or syphoning back? 30 gal fresh tank. 9gal w/heater = aprox 1/4.
putback is offline   Reply With Quote
Old 10-22-2013, 06:13 PM   #6
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
If your door is the locking type like mine, I just tape it over for storage with aluminum tape.....Phil.
pgr32e is offline   Reply With Quote
Old 10-22-2013, 06:14 PM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Is there actually water in the fresh water tank or is that what the monitor is telling you?
TB & Greg and Abbey Schnauzer
#3954
Old 12-02-2013, 08:07 PM   #8
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
The fresh water fill has a vent opening adjacent to it. It is typically a small opening with a screen over it. If water were flooding into the hatch where you fill the potable water tank, I suspect water could run in through the vent. It is simply a piece of tubing off the top of the tank to vent the tank as you fill and empty. The recommendations here to prevent water running into the hatch are good ones.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
