Old 09-21-2004, 07:37 AM   #1
rex
rex's Avatar
Questions About Valves
What position (open-closed) should the valves in the service center be in hooked to city water? Does the water pump switch need to be on while hooked to city water?
rex is offline   Reply With Quote
Old 09-21-2004, 07:43 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
The valves on my '67 Overlander's "One Stop Service Center" are all drain valves for winterizing. They should all be closed during normal operation.
The water pump switch should be off while hooked to city water as the city is providing all the pressure you need.
Tom
Old 09-21-2004, 07:59 AM   #3
rex
rex's Avatar
Tom
Thank you for your quick reply! We are new to this and have so many questions. My husband is in process of replacing the toilet. Do you have any advice?
Old 09-21-2004, 08:06 AM   #4
TomW's Avatar
1967 26' Overlander
...in process of replacing the toilet. Do you have any advice?
Make sure the one you pick will fit the space. When forced to replace my Aquamagic Deluxe, my first thought was to go with Thetford's Aquamagic V. Problem was, it did not stand a chance of fitting the limited space.
Acting on forum member Janet's advice, I checked the dimensions on the Sealand Traveller Lite. It fits the cubby hole very well.
Good luck,
Tom
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
Airstream / extended stay questions krowsea Our Community 5 08-20-2004 04:35 AM
Argosy rear air bag leveling valves. Mark K Airstream Motorhome Forums 5 09-15-2003 04:34 AM
Leave Propane Bottle Valves Open? heyskipper LP Gas, Piping, Tanks & Regulators 3 02-23-2003 08:19 PM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
