My '73 has a brass check valve on elbow coming out of FW tank basement feeding pump intake that sticks closed - I primed pump, tried everything but it only allowed water to flow after rapping the fitting with a big wrench. The fitting looks a little like some of the gas-line compression nuts except it is about 1 1/2 inches long. Also at that point had the original strainer cup gasket fail so it would suck air from there - R/R the old one ...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
