Old 10-08-2016, 09:05 AM   #1
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
Push in fittings ok?
I want to install a below the sink water filter, the Filtrete , that connects with the push in fittings. Do others use this or similar filters with these fittings and have you had any leaking problems with them? I use these at home in two places and have never had issues, but since the AS has a movement element I'm not sure if these will be ok.
Southern Belle on the road
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 10-10-2016, 10:41 PM   #2
2013 30' Flying Cloud
Greenwood Village , Colorado
I don't have any issues with them. We just had a new Truma water heater installed and that is what they use.
sunahara is offline   Reply With Quote
Old 10-10-2016, 11:27 PM   #3
Gold Country , California
Push in fittings have been around for quite a while in the plumbing trades. I think they would work well for a moving and shaking home, the moving and shaking should be easily compensated by the plastic supply lines used.
NorCal Matt is offline   Reply With Quote
Old 10-11-2016, 06:46 AM   #4
Navarre , Florida
Thumbs up
Thx for replyies. That's what I'll do
Old 10-11-2016, 07:50 PM   #5
2000 34' Limited
1985 25' Sovereign
LaGrange Highlands , Illinois
Yes I use them and there is no problem. The best part is U can take them apart if needed
rmatkovich is offline   Reply With Quote
Old 10-12-2016, 12:09 AM   #6
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Just don't use them on the suction side of the water pump, as in winter bypass kits. They will suck air as they use pressure to keep them sealed.
guskmg
Old 10-12-2016, 07:40 AM   #7
1996 25' Excella
Tillsonburg , Ontario
The only other down side I found was that they swivel. I Used them on a filter installation and had to add extra support to keep the filter in place since the piping was adding nothing in the way of stability. Good info about suction side use. Thanks
JCW
JCWDCW is offline   Reply With Quote
Old 12-31-2016, 04:45 PM   #8
Navarre , Florida
Update. I did install an under sink filter system with the push fittings. Mounted filter housing securely and stabilized the water lines to keep them from moving too much. Several trips later and all is well, no leaks.
DBLee and Southern Belle on the road
Copper compression fittings vs. flare fittings phippsto LP Gas, Piping, Tanks & Regulators 37 12-07-2015 04:08 PM
Steps are too hard to push in Okie1 Steps 14 02-08-2009 10:14 AM
Help! 1/2 x 3/8 x 3/8 push fitting glacierrunne Fresh Water Systems 7 06-05-2006 11:04 PM
Looking for push bar tyndalelady Our Community 3 02-02-2006 08:33 PM
