Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 09-22-2016, 03:33 PM   #1
Indianut's Avatar
1972 Argosy 22
Dallas , Texas
Pump won't turn off
OK so I finally got to the point of putting water to my Argosy 22 and it does not leak anywhere!! Only problem is that the water pump will not turn off. I have Excellent pressure everywhere, more than I figured I would, but the pump will not stop running. There is a little diode looking thing that has a wire coming from each end that is attached on one side where the pump plugs into the wires, but it is just dangling there and not attached to anything on the other side. It does not seem to effect the pump, like I said, it pumps great, it just will not turn off! Please help. Thanks, Danny
'Dallas' Dan
https://www.wildwheelsthrillarena.com/home.html
Indianut is offline   Reply With Quote
Old 09-23-2016, 12:29 AM   #2
1979 23' Safari
Wayland , New York
What kind of pump, how old. Sounds like a bad pressure switch in the pump.
Old 09-23-2016, 07:28 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the pressure switch was bad and the pump continued to pump it would bog the pump down against the system pressure.
If the pumps continues to run the diaphragm may be leaking back and not allowing the pressure switch to reach cutoff or you are pumping water somewhere, major leak.
I am assuming you do not have an older demand system where the pump maintains a pressure head on the air above the water line in the tank. If that is the case and there in very little water in the tank the pump will run for a long time before it can build pressure in the tank.
2004 Excursion 4x4
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
New pump won't turn off bearhere Fresh Water Systems 12 06-19-2014 02:23 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
won't turn off! AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-22-2009 09:52 AM
Fridge Fan won't turn OFF clancy_boy Refrigerators 7 09-04-2007 08:55 PM
