Old 01-16-2009, 09:32 AM   #15
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Gnored, there are a some other replacement options and more info in this thread here. The same Grover compressor is still available, but are more pricey than some other options.
The Grover compressors had a cut-off switch at 60 psi. You really don't want to go over that pressure with original plumbing. Ask me how I know.
Traveling With Elvis
life with a 1956 Sovereign of the Road
• • • Aluminocentricity • • •
Sugarfoot is offline   Reply With Quote
Old 01-19-2009, 07:45 PM   #16
AnEyeForTexas
Lockhart , Texas
Air Pump Redux
When I'm under the sink, I can't see anything because the pump is too far away for my bifocals, and too close to be seen otherwise.
Of course, there's also the issue of no 12 Vdc on the wire descending from the bulkhead.
Sigh ... I think this is beyond me. I'll probably have to seek professional help. Hope there's someone in Alpine, TX who can fix it.
BTW -- here are pics of the water tank and associated plumbing. There are no signs of any leaks having ever happened, so maybe that's grounds for hope ...
ID:	74245   Click image for larger version
Name:	water heater side.jpg
gnored is offline   Reply With Quote
pump water air
Water pump air lock? TY PECK Plumbing - Systems & Fixtures 10 12-09-2011 06:18 PM
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 08:52 AM
Winterizing & Water Pump Access 27FB DMT Winterizing, Storage, Carports & Covers 28 11-17-2011 06:15 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
