Old 08-17-2014, 11:20 AM   #1
jcain63's Avatar
1972 25' Tradewind
lancaster , California
Pump doesn't shut off
So, I finally fixed all the leaks in my 72 tradewind. But, my pump never fully shuts off when all the valves are closed indicating that I have a leak somewhere. I let the pump run for 30 min or so and no leaks or running water of any kind. When standing above the tank area if I put my head close to the floor I can hear a faint bubbling sound. But, no leaks or running water. I have the old fresh water refill. Could it be sucking air through this and not allowing the system to pressurize? Any help would be great. Thanks. Click image for larger version
Name:	ImageUploadedByAirstream Forums1408295988.873340.jpg
Flo is getting a make-over!
jcain63 is offline   Reply With Quote
Old 08-17-2014, 01:35 PM   #2
richw46's Avatar
Lexington , Kentucky
Are you sure the pump is good? How about the seal around the pump inlet? Could it be sucking air? How's the water pressure in the lines? Good or weak?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-17-2014, 02:33 PM   #3
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by jcain63 View Post
So, I finally fixed all the leaks in my 72 tradewind. But, my pump never fully shuts off when all the valves are closed indicating that I have a leak somewhere. I let the pump run for 30 min or so and no leaks or running water of any kind. When standing above the tank area if I put my head close to the floor I can hear a faint bubbling sound. But, no leaks or running water. I have the old fresh water refill. Could it be sucking air through this and not allowing the system to pressurize? Any help would be great. Thanks. Attachment 219221
Did you open all the faucets for a few seconds to let the air escape ?
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 08-17-2014, 03:06 PM   #4
jcain63's Avatar
1972 25' Tradewind
No faucets are installed yet just shutoff valves. The pressure is good. Not great but good. However when I open both hot and cold valves in the bathroom the hot line is a dribble and the cold line runs good. What's the pressure suppose to be?
Old 08-17-2014, 03:13 PM   #5
Airstream Driver
1997 30' Excella
Images: 51
can you stick a temp line on the shutoff valves and let the air escape ?
1996 Airstream B190
AIR #13
Old 08-17-2014, 03:16 PM   #6
jcain63's Avatar
1972 25' Tradewind
I've let the lines empty into a bucket and closed them under water to ensure the air is escaped.
Old 09-01-2014, 02:27 PM   #7
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
If there is no air coming through the lines then the pump is suspect. It could be leaking back through the check valve.
Gearheart is offline   Reply With Quote
Old 09-01-2014, 02:59 PM   #8
jcain63's Avatar
1972 25' Tradewind
That was going to be my next fix. I don't know how long the pump has been there. I bought the trailer in the high desert in CA with the door and the back window removed. So the WHOLE thing had roughly 1/8" of dirt inside. Amongst other adult "goodies". Lol. So gross!!
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
AC/heat pump runs continuously unless shut off manually lsinclair Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-13-2010 07:47 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 04:55 AM
1986 AS 345 MH Magic Chef Shut off Valve? Jim Tyrney Stoves, Ovens & Microwaves 2 10-14-2003 01:48 PM
Shut off valve, 1992 30' Motorhome dwc Mechanics Corner - Engines, Transmission & More... 0 07-01-2002 04:50 AM
