Old 02-16-2010, 09:47 AM   #1
2008 25' Safari FB SE
Spicewood , Texas
Pulsating water pressure,2008 Safari
Sometimes the water pressure is smooth as a babys butt,but after I move and set up the water pulsates .
Usually it clears up in time,an hour of operation,but this time it is not.
What could be the problem?Is this something I could fix myself?
Might it be a bad pump?
kingfisher is offline   Reply With Quote
Old 02-16-2010, 10:13 AM   #2
In my 2004 Safari the water pulsates a little bit and the pump makes a vroom vroom cadence at low to moderate flows. This seems to be the nature of the water system. If the sound is sufficiently annoying, you can install an accumulator tank which will force the pump to cycle on and off more regularly.
handn is offline   Reply With Quote
Old 02-16-2010, 10:28 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Not sure what you are saying.
Low flow, faucet not complete turned on, can cause the pump to Short Cycle, coming on and off frequently. This will change to flow rate at the faucet as the pump cycles.
If this is the case installing a small expansion tank with a diaphragm will extend the cycle rate and even out the flow. This will show you what I mean.
http://legacy.shurflo.com/pages/Food...nks/tanks.html
2004 Excursion 4x4
Old 02-16-2010, 11:19 AM   #4
fmrcaptevil's Avatar
Weldon Spring , Missouri
Try bleeding the air out of all of the water supply lines (cold & hot), including the shower. It can take several minutes, so unless I'm on a full hook-up, I live with it. I thought the pump was bad, too.
fmrcaptevil is offline   Reply With Quote
Old 02-16-2010, 11:20 AM   #5
I don't think he's referring to the normal cycling of the pump.....
Old 02-16-2010, 11:28 AM   #6
HeadnOut's Avatar
Ruther Glen , Virginia
could be air in the lines also check your pump filter, make sure there is no trash build up on the screen
Keep your nose to the wind and your eyes on the horizen.
HeadnOut is offline   Reply With Quote
Old 02-16-2010, 11:39 AM   #7
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Sounds like air in the line, be certain to fill the water heater and bled the air before turning it on.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 02-16-2010, 12:26 PM   #8
HowieE's Avatar
Images: 12
Neither air in the lines or a partially filled hot waster tank would have the effect of pulsating the flow rate. Pressure in a liquid system is equal in through the system only effected by height and then only at a rate of about 1/2 per foot. Not a question here.
Please advise if the pump is cycling a the same rate as the pulsation.
If the pulsation is faster then the pump cycle rate look for an air leak on the suction line coming from the tank to the pump.
2004 Excursion 4x4
Old 02-16-2010, 01:39 PM   #9
2005 19' Safari
GLENDALE , AZ
We have experience the same thing when the fresh water tank is low (almost out of water), which puts air bubbles in the line. I agree with the others and think you should purge the lines, before you do anything else. That may fix the problem; and it's free...
Old 02-16-2010, 02:27 PM   #10
1979 30' Argosy
Milwaukie , Oregon
Make sure the fresh water tank is full, then run the water at the furthest outlet from the pump. That'll usually clear the air from the lines. If you fresh water tanks isn't almost full when towing, turn off the pump.
dodgedude is offline   Reply With Quote
How much water pressure is too much? Dreamnair Fresh Water Systems 10 09-17-2009 07:16 AM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 09:17 PM
water pressure starflyte1 Fresh Water Systems 5 11-14-2006 01:07 PM
pressure tires for safari frederic.c01 Tires 5 08-04-2006 02:54 PM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 05:45 PM
