Old 10-12-2003, 01:07 PM   #1
DaveJ's Avatar
Problem Filling Fresh Water Tank
Hi again,
The 92 Land Yacht MH I just bought has a venting problem while filling the tank. When I lift up the bed and look at the inlet line to the tank, the line is not very level but undulates so the water tends to seal up and prevents the air from escaping.
Is there an easy way to fix this or is there a tank vent somewhere that could be clogged? What I can do until I find a way to fix it is run a long thin hose into the tank to get the water past the air pocket in the line. Haven't tried this yet but the only thing that might not work here is the line might not be able to go all the way in.
Thanks.
Dave
DaveJ is offline   Reply With Quote
Old 10-12-2003, 01:24 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
When you looked under the bed was there a small 1/2 inch line that was connected to the top of the tank?
In the older units there was a hole in the filler pocket that the expelled air would come out of. When we were full the vent would spit at you and you knew you were full.
On the newer models there may not be such a vent. The thinking being that the air would vent from the main fill tube.
Is it possible to replace the filler tube with a newer, longer, unlooped tube?
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 10-12-2003, 02:00 PM   #3
DaveJ's Avatar
Hi Brett,
No I don't think I saw a tube on the top of the tank but I'll take a closer look this afternoon.
I might even photograph it and post the photo if that helps. Will be taking pictures of something else I need to post a question about, anyways.
Regards,
Dave
Old 10-12-2003, 02:07 PM   #4
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I had the same problem on my 2003 International; the filler would spit back at me and take a long time to fill.
I found that the vent hose had been kinked just above the tank when the trailer was built. I cut the vent line at the kink and inserted an elbow fitting. After that was done, the tank filled quite well.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 10-13-2003, 08:02 PM   #5
I have a similar problem with my 92 Excella.
The tank does not fill all the way.
I have taken the filler apart, and everything is OK.
The vent line does not to seem to be kinked. Here is picture where it goes into the tank.
Any idea ?
Name:	water tank 92-29.jpg
icedream is offline   Reply With Quote
Old 10-13-2003, 08:14 PM   #6
JPAIRSTREAM's Avatar
1972 31' Sovereign
, Ohio
Images: 47
BLOW AIR IN VENT LINE SEE IF THERE IS SOME SORT OF BLOCKAGE THERE. MAYBE SOMETHING BUILT A HOME IN THE LINE... JUST A GUESS.. NO FACTS.
JP
JPAIRSTREAM is offline   Reply With Quote
Old 10-13-2003, 08:21 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
pull the plug?
ice dream,
first, welcome to the forum! i have a '92 '29 also.
when you fill the trailer do you remove the plug from the filler vent?
it is on the outside just above the main filler opening, part of the plastic retainer pulls out and allows air out.
how did you get that pic? shove the camera way back?
this is what the top of my tank looks like!
john
Name:	low point drains.jpg
you call them ferrets, i call them weasels.
Old 10-14-2003, 01:12 PM   #8
At the beginning no. I did not realize it was a plug. I could hear the air comming out though (and I was afraid to break it).
Then I took the filler apart and tried again to top the tank, with plug remove. No change.
I used an air tank, but got same result by just blowing into vent line: at some point, water squirted out through filler. I know for a fact that the tank is about 3/4 full.
It looks like at some point, the vent line is bellow the water line. ???? How is that possible?
I have just bought a new vent tube and I will try to replace it. You never know.
Old 10-14-2003, 05:36 PM   #9
DaveJ's Avatar
I just got back from my first camping trip (!!) and took a closer look at the tank. There is a clear plastic vent tube coming out near the filler inlet on the left side of the tank (looking from the hallway towards the rear bed). Also it looked like the small tube was discolored near the tank. It looked dark on the inside of the pipe. Not sure if that's a clog.
I saw some of the other comments that mentioned a vent plug near the filler hole on the poutside of the MH. I didn't see a vent plug outside. I'll (again) take another look when I get back to the RV. What I think I remember seeing was the vent pipe under the bed going from the left side of the tank to the head area of the bed somewhere and the end of the tube goes off somewhere into the wall, perhaps.
Fresh water tank leak Flex Fresh Water Systems 3 09-30-2004 04:25 AM
Water Leak/Auxilary Tank Filling.... actioncraft Fresh Water Systems 5 03-25-2004 11:29 AM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 12:37 PM
Leaky fresh water tank nellie the elephant Fresh Water Systems 3 10-13-2003 02:12 PM
Fresh water tank - slow drip drboyd Fresh Water Systems 5 07-24-2003 07:01 PM
