Old 06-08-2007, 09:53 AM   #1
chapparel's Avatar
1965 22' Safari
Three Rivers , California
prime water system?
Do you need to prime the water system to get it to work.
Pump seems to be OK. How do you prime the system to start
the system?
chapparel is offline   Reply With Quote
Old 06-08-2007, 10:10 AM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
My tank is higher than my pump - I don't have to prime. How is yours oriented?
Dave
Fyrzowt is offline   Reply With Quote
Old 06-08-2007, 10:10 AM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
The only problem I've had in getting my water system to work is 1) not enough water in the tank; 2) sucking air from a leak between the tank and pump. Oh, I did have to replace a pump once that 'appeared' to be working fine.
Neil and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-08-2007, 11:29 AM   #4
chapparel's Avatar
1965 22' Safari
Thank you Fyrzowt and anholman. I will check out both of your suggestions.
Fyrzowt, your Profile says you are in central Ca. Would you mind telling me
where you live?
Old 06-08-2007, 01:36 PM   #5
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
If this is the first time since winterization, all the water may be going into the water heater. Six or ten gallons is a lot to fill, it takes a while, and the pump is working fine the whole time. My trailer flows hardly any water to the sinks at all until the heater tank fills
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 06-09-2007, 08:39 AM   #6
Fyrzowt's Avatar
2000 25' Safari
Images: 8
where you live?
Templeton, between Paso Robles and Atascadero.
I have friends in Three Rivers.
Dave
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
