Old 10-25-2002, 05:43 AM   #1
Pressurized water tank
I just bought 63 Tradewind. It has a cast pressurized water tank. I need advice; Should I replace it with plastic when I put in the gray water tank? Or leave it? Also where is best place to put gray tank?
It appears that Airstream did not begin publishing service and instruction manuals until a couple of years after 63, is a manulal for 65 or 66 same church differant pew?
Any and all resteration suggestions welcome.
eracism is offline   Reply With Quote
Old 10-25-2002, 06:52 AM   #2
LOST , Hawaii
A gray tank it needs to be near the black tank for ease of dumping, it is easiest if both discharge lines merge after the valves. Consider where the existing gray lines are so you don't have to make major changes in them. When you mount this remember water weighs a little over 8 lbs a gallon.
If your fresh water tank is good changing it is going to be a trade off. A plastic tank will require a pump, and they are the subject of many complaints because of noise. I would try it for awhile, if it doesn't work, change it later.
John
74Argosy24MH is offline   Reply With Quote
Old 10-25-2002, 07:09 AM   #3
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
grey tank link
For your reading pleasure on grey tanks.
Smily
http://www.airforums.com/forum...&threadid=2180
smily is offline   Reply With Quote
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 09:16 PM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 01:37 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 08:59 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 08:26 AM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 07:11 AM
