11-20-2007, 11:21 AM
2020 30’ Globetrotter
2001 30' Excella
Phoenix
Pressurized Water Filler Tube
I am considering replacing the black rubber filler tube that runs from the valve on the outside of the trailer to the tank under the kitchen sink. I have a 62 Ambassador with a pressurized galvanized tank. It appears that the current hose is black rubber similar to an automotive radiator hose. The system has no leaks and holds pressure, however I noticed a small hairline crack in the outer skin of the hose and want to replace it. I have not been very sucessful in my search of this topic on the forums. I believe that the inner diameter of the hose needs to be 2-3/4" Has anyone done this replacement and what material was used? Any advice is always appreciated.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
11-20-2007, 01:38 PM
1971 21' Globetrotter
Arvada
11-20-2007, 02:32 PM
Corona
The original filler neck was fastened directly into the metal tank with a section of pipe.
No hose was used.
11-20-2007, 02:57 PM
Always Airstreaming!
2005 22' Safari
1960 24' Tradewind
Anytown
, Connecticut
Originally Posted by Aerowood
Too funny! US Plastics is one of our suppliers for the Tygon we use on our presses! They are really great to work with and their Tech Support is pretty good too! You will find they have lots of cool stuff when repairing or upgrading your AS. I even buy stuff just to make more stuff around the house!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
11-20-2007, 03:38 PM
2001 30' Excella
Phoenix
No hose was used.
Thanks Andy,
I will have to remove the hose and see if there are threads under there and try to replace the pipe section. The rubber hose is pretty old and looks like it could be original.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
11-20-2007, 04:33 PM
Corona
Thanks Andy,
You can pressurize your water tank to 100 psi.
A rubber hose would never take it.
11-20-2007, 06:41 PM
More than one rivet loose
Los Alamos
, New Mexico
Just what kind of rubber hose are you talking about? We have rubber hoses in airplanes that will take 1000-1500 PSI, reinforced of course.
Michelle TAC MT-0
Sarah, Snowball
